Already have 1" wide, hubcentric H&R wheel spacers on the front of my 2.4FI GT, so naturally I looked there first . . . hmmm, $150 for a pair of 25mm (~1"), 4x100mm, 12Mx1.5 studs, 57.1mm hub, ~$330 for all four wheels including shipping. Those Krauts sure are proud of that TÜV certification, aren't they! Poking around on the net a bit more, I discovered a generic set with the same specs, but with a hub-bore of 64mm, i.e. not hubcentric, but at less than half the cost, ~$70 a pair at ezAccessory.com! Not exactly what I wanted, but close. Poking around a little more at their site, I was delighted to find that they also sold poly carbon hubcentric rings with a common OD of 73mm and different IDs for various hub sizes, including Opel's - 57.1mm . . . $16 for a set of four! Bought two sets of the adapters (4) and one set of the hub centric rings for a total just under $180, including shipping! . . . I was a happy camper! Suppose you noticed the disparity between the wheel adapter's hub bore - 64mm, and the hub centric ring's OD - 73mm, huh? Took both adapters and rings to my machinist (don't have a lathe of my own . . . yet!), and had him machine the adapter's 64mm hub bore to the 73mm ring OD and, VOILA! . . . the correct 57.1mm hubcentric 1" wheel adapter! . . . and $20 to my machinist! Just installed my new hubcentric spacers . . . they fit perfectly!
Otto,
Any chance we'll see before and after pics? Todd
pre/post pics . . .
. . . of the wheel adapters, no . . . of the Ascona, possibly yes.
No problem on stock setup, as it fits inside the rear of any one of the original steel wheel spokes. These bolt extensions must be cut flush with the hub's wheel mounting surface to mount the front wheels' spacer/adapters, however. Cutting disc on an angle-grinder made short work of this in my case.
It could be something from the assembly line, in that when at the phase where the wheel/tire is to be put on for the first time, it could be a quick "locating" point. Just a thought. But, I have seen these on 75 cars, and as Otto has stated a quick touch with a grinder makes it dis-appear
You guys are lucky
, wheel spacers are a very big "no-no" here
. . . even German TÜV approved H&R wheel adapters?
Real Name: Jim
![]() Provided Answers: 7
Clever fix Otto,
I'm going to save this thread for future reference... Jim
Yes, even German TÜV approved, because the German TÜV is not recognised here in Holland.
1970-GT
Otto, nice find!
The spacers are made from billet aluminum, and only 1" wider than stock. Plenty strong enough for a 2,200 pound car. The low profile tire/wheel will be damaged before the spacer/studs break. I have thought about widening the rear spacing on my GT for years. The front fills the wheel well area perfect, but the rear looks very narrow. I have 14 x 6" wide wheels. 195/60R-14 tires Any pictures of your widened GT? Are the spacer nuts included? Being a machinist I might make a couple 64mm OD x 57.1mm ID aluminum spacers. $20 to modify the hubs, and spacers! Why buy a lathe? Thanks for the info. Lyle Last edited by Tru-Craft; 09-10-2008 at 11:29 PM. |
#14 (permalink) | |
![]() Years ago I bought H&R 1" adapters for my 2.4 FI GT on which I have vented rotor front discs from BMW . . . widened rotors caused some rear mount issues on rare 13" alu rims I'm using . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-12-2008 at 03:53 PM. Reason: add reply info . . . clarity |
#15 (permalink) | |
#17 (permalink) | |
1970-GT
On our Go-Karts I learned basic chassis setup, don't know alot, but widening does make it push (Understeer). Not good! The only thing you can do is slow down to make the corner............not good in a race! We always set it up loose (Oversteer), this way it wouldn't bind the solid rear axle. Way faster through a corner, if you can catch it before it spins. My GT has: Front and rear sway bar. Lowered front spring 1-1/2" Stock rear springs. Shocks, Monroe something? Poly bushings. 195/60R-14 Yokahoma's Bob, I want the car to look good, yep, getting old and I don't race on the streets as much anymore : ( My GT is pretty neutral as it is, don't want to mess it up too bad. Things that have helped reduce understeer: Lowered front end. Stiffer front spring. Rear sway bar. I do want to widen the rear. How about softening or removing front sway bar? Use 1/4-3/8" front spacers? Any thoughts? Lyle |
Lyle
One thing Bob has stated in the past is to widen the front by at least 1/2". You'll notice from the track widths Bob gave above the front actually needs to be widened by 0.6" to equal the rear. The other thing that could be done is to use a different wheel offset in the rear to narrow the track. Alot of FWD autocrossers use this trick to adjust handling at different courses... as they will carry several sets of rear wheels with different offsets...
Paul |
Well, I just installed a set of the same [Post #1] 1" wheel spacers with identical "hub-centric" inserts machined to fit on my sprint Kadett LS and must say that I'm real pleased with the new look and "stance" of my Kadett!
Now, to answer questions that are sure to follow, this time I did take "before/after" pics . . .
#20 (permalink) | |
Driver
Real Name: George
#21 (permalink) | |
Opel Intern
What about the suspension?
The way i see it, the original lugs are secured tightly by the adapter and the it provides the extended lugs which then secure the new wheel, so now leverage and therefore stress is added to the externals of the system. But what about the internals, ie the different bearings, ball joints and tie rods? If the offset brings the center line of the wheel back into alignment, would that all be alright? Enlighten me as I am lost . . . (it doesn't just have to be Otto either) Thanks in advance, Jay Swift |
#22 (permalink) |
UFO pel abductee.
As long as the stock track, (center of tire tread to center of tire tread easily
measured from inside sidewall o one tire to outside tire of the opposite side), isn't widened much more then 1/2" total with wider wheels and spacers/adapters, bearing loads won't be significantly effected. Beyond that long term durability of the wheel bearings could be a problem particularly if you drive aggressively. In the case of Otto, it may never be an issue since I understand he drives like an old lady.
#23 (permalink) | |
Opel Intern
) In particular, I am thinking about the very touchy and sensitive pinion gear in the Diff. I really don't want to have to find more of those in a long time.I think that I'll be alright, if not, whats the worst that can happen, a wheel falls off?
#24 (permalink) |
UFO pel abductee.
I don't see any way widening the cars track width with wheel/spacers or
wheel adapters would have any effect on you differentials durability. The only ways to damage the rear gears and bearings on the Opels from my experience would be to run the diff low on oil or trailer the car while in gear. The shifting back and forth while tied down on the trailer will hammer spots on the gears from the engine and drive trains inertia. In the '70's and early 80's I SCCA road raced my Ascona in showroom stock B class and really hammered the whole car. The only failures on the track where the breaking of wheel centers due to the tremendous cornering loads and catching the edge of the track ruts. I rolled tires off of rims a couple of time despite 45-50 psi air pressurs. If you drive as hard on the street, you won't live to be 19 let alone see any differential failures. ![]() If you do seriously hard burnouts you might though.
#25 (permalink) | |
Opel Intern
Ahhh, see, I am of the drifting culture where smoke and tire spin are all a part of the game (legal of course). I don't think that I will be drifting the GT though, it is already too stylish. Goin sideways would just blow people's brains to bits!!! ![]() If what you are saying is that it is an OK for street use, as in daily driver, then I am all for it. |
