Old 04-24-2007   #1 (permalink)
gr_diver's Avatar
Differential gasket
Hello friends!
I had an unfortunate thing happen today. The filler plug on my differential had it's allen head destroyed years ago, and as a fix, somebody had welded on the hex head of a 19mm bolt. While trying to open it today to top up the lubricant, the two welded pieces separated and I am left with a stuck plug with no usable head...
I am thinking of taking the whole cover off, take it to a machinist to remove the old plug, buy a new plug (as it should have been done in the first place), and re-assemble.
The local shops though do not stock the cover's gasket anymore... What is it made of, so as to have one made by a "gasket shop"? Is it paper, or something more exotic like permanite for example?
Thank you in advance!
'78 Opel Ascona B 1.6SR
gr_diver is offline
Old 04-24-2007   #2 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
nothing so significant
They are just cork, and there's no reason why you shouldn't be able to just use a quality RTV gasket maker instead. Don't even mess with having a gasket made, it's not worth the expense.
oldopelguy is offline
Old 04-24-2007   #3 (permalink)
opelnut10's Avatar
diff. cover plug
Take the two bottom bolts out of the cover, that will allow most of the lube to drain then take the cover off, Opel had two differant pulus, one with the allen socket and one with a 13mm square head. If you can find one the square head is much easier to get in and out and the allen head fills up with road grime and the allen wrench cannot get all the way down in the hole and strips out. RTV Gasket maker is the trick, clean both surfaces good and put the RTV on the cover, allow it to set up for about 5 minutes then install it on the dirff.
opelnut10 is offline
Old 04-24-2007   #4 (permalink)
www.opelgtworld.de
opelgtworld's Avatar
opelgtworld
Lightbulb
Originally Posted by oldopelguy View Post
They are just cork
I think it`s a paper gasket...
Gasket Paper Material, scissors and Mc Gyver technics
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)"
opelgtworld is offline
Old 04-24-2007   #5 (permalink)
No Access
It's a 1.0mm paper gasket not cork. Pretty easy to cut out, but they still sell them for cheap here in the U S. I'm sure Jim at Opel USA would be more than happy to send you one.
nobody is offline
Old 04-24-2007   #6 (permalink)
OpelJim's Avatar
OpelJim
Nice
Thank you nobody
YES you are right I have one last OEM Opel gasket left to send to whomever needs one
Give me a call
Jim
OpelJim is offline
Old 04-24-2007   #7 (permalink)
gr_diver's Avatar
Thank you all for your replies!
Jim, it is very kind of you to offer to send me the gasket. But shipping costs would be the same (if not more) than to have a couple of them made by a local gasket shop... Thank you very much though, I appreciate it!
gr_diver is offline
Old 04-24-2007   #8 (permalink)
No Access
I was curious, so I checked shipping. It can go by letter and would be around 4 dollars US and 4 to 7 days. Not bad, really.
nobody is offline
Old 04-24-2007   #9 (permalink)
OpelJim's Avatar
OpelJim
Did not think you were overseas (should have noticed )
It could cost about the same depending on what your local gasket shop is going to charge you.
My gasket costs $9.50 and it is the OEM Opel part
I wonder if Global Priorty Mail is $7.00 or $8.00 to get it to you ??
Hey whatever works for you is ok by me
Nobody your so thoughtful and helpful once again thank you for your suggestion.
OpelJim is offline
