Metric Bolt Specs
Hope this helps - I can't remember the size of the bolts that hold the torque tube to the differential, or the grade but, I would assume they are 8.8
If the head is 10mm it is a 6mm bolt
If the head is 13mm it is a 8mm bolt
If the head is 15 (or 16) is will be a 10mm bolt
Multiply by 12 to get inch lbs.
As far as the filler plug is concerned, most people just get it snug enough so it doesn't leak.
Hope this helps, Tom
LinkBack URL
About LinkBacks
