Noise after pinion seal
Thanks Bill.If your thinking brake drum they didn't do any work on that . It has to be something between the tranny & the pinion seal that they replaced.Something overtightened or missalighned or a bushing or something not put back.Basically your hearing the drive shaft turning when your moving.
Can you properly support the car and let the engine idle and get under it to try to pinpoint the sound? With the car in neutral and the e brake off the tires will usually rotate slowly and you might be able to safely locate your problem. For that matter if you have a helper to rotate the wheel instead of using the engine to, you won't have to contend with engine noise.
Harold Last edited by hrcollinsjr; 05-03-2009 at 05:58 PM. |
#8 (permalink) | |
I would strongly think your mechanic checked the brakes on the 30+ year old car. |
#9 (permalink) | |
The "Spring"
Check to make sure that if they removed the driveshaft that the spring which goes inside the yoke on the tailshaft of the g/box was there and has been replaced. That spring loads the driveshaft back against the dome/button which goes on the end of the pinion to prevent the whole driveshaft 'wandering' back and forward.
Often removed ... and not replaced ... by P.O.s The shop should remember the spring as it is one of Opel's special features!
#11 (permalink) | |
