Fitment of rear gears in axle
1. - naturally, they are for the larger style axle, for the CIH engines; 2. - I know that the gears by itself share a common carrier for the 3.18 and 3.44. For any higher ratio, the carrier is different. What about a 4mm spacer I heard about? 3. - Since my 3.18 includes the complete carrier, bearings and what not, would they fit in any large housing? With or without spacer? 4. - Does it make a difference whether it's an early style axle, or a later style (with the different bearings)? Can one style carrier fit the other by using the correct bearings? 5. - What is the exact difference between the different bearings, to tell whether my set has the old or new style? Dieter
Where are our rear end specialists? (No, I'm not thinking what you think, Roy...
)Dieter
Dieter;
I don't know about the 3.18 gears, but, you can put the 3.67 gears in the 3.44 axle, but, it requires a 3mm spacer. This is what I have heard. I know "oldopelguy" Stephen has put 3.18 gears in just about every one of his Kadetts, he might chime in here.
Dieter
PS, I have 1969 Kadett wagon I will be parting out soon, it has the 3.18 rear axle with anti-roll bar mounts on it. If you want it you are welcome to it!
#11 (permalink) | |
Uber Genius
![]() Question aswered though. For the GT, the diff gear ratio (stock) are all the same with the 1.9.
