Doug
GT Differential (was Axle) Swap
My 72 is getting a little noisy back there and there is a $300 73 (siezed engine) not far away that could be a donor. Thanks for the help
Doug |
Different, but only in the details. If you want to swap an entire differential, the early outer roller bearing/internal C-clip floating axle differential (1969 and 1970) can be replaced as a unit with the later sealed outer bearing w/pressed retainer ring non-floating axle version (1971 and later). And vice versa but then you won't like the unavailability of outer roller bearings if you ever have a problem.
By the way, welcome to the forum. ![]() Harold |
Check the hand brake cable too though. Early years used a "ball" and later years use a "hook" on the end to activate the parking brake.
