1.5L Rear end?
Opelitis since 1984
Real Name: Charles Goin
Can't speak if its a 1.5L or not..
But a Manta rear will not work in a GT with a lot of mods. The Kadett 1.5L will though and its a 3.18 rear end. Which is whay they have been installed (For highway driving and MPG)
Kalifornia Kid
The 1.5L 4-speed 1968 Kadett originally came equipped with a 3.67 ratio "rallye" rear axle.
Compared to the standard 3.44 rear axle, it will lower your highway top speed and will cause lower gas mileage, but it will enhance your performance in low gears from a standing start. The 3.18 axle was originally installed only in 1.9L Kadett Wagons (1968-1972) with an automatic transmission. It will cost you low-speed performance, but adds high-speed efficiency, and as such is best when installed with a high-torque Opel motor (such as a fuel-injected 2.2 or 2.4L) and a 5-speed GETRAG transmission. The only way to know if you have a rallye 3.67 axle, is to remove the plate from the differential and count the teeth on the main gear. 31 teeth = standard 3.44 ratio. 33 teeth = rallye 3.67 ratio. One advantage of the 3.67 axle housing, is it has been described as larger than standard 3.44 Opel axle housings, and has been used for installation of taller Quaife-brand 3.89 and 4.11 gears (ask "Rally Bob" for more information on those). Please be cautious, regarding the source and accuracy of the Opel information you rely on -- If misrepresentations occur (such as during a sale of an Opel part as a 'performance' part, when it is no such thing), then you can be vulnerable to a charge of misrepresentation or fraud. (This was submitted on DG's account name -- as the PC was already logged in to this site -- but was written by another person). |
1968: 3.18 was used in ALL 1.9 Kadett models, MAN and AUTO, except in the 1.9 Rallye. 3.67 was used in all 1.5 models and the 1.9 Rallye. 3.89 was used in all 1.1 models. There was no 3.44 rear end offered. 1969: 3.18 was used in ALL 1.9 AT Kadett models except the 1.9 AT Rallye which had a 3.44, which was also the ONLY rear end ever offered for all 1.9 GTs, MAN and AUTO. 3.67 was only offered in the 1.9 Rallye Kadett with MAN. 3.89 was offered in all 1.1 Kadett models except for the 1.1SR powered wagon (39) and Rallye (92) which had a 4.11. 1970: 3.18 was used in ALL 1.9 Kadett models, both MAN and AUTO, except for the 1.9 Rallye which used 3.67 MAN and 3.44 AUTO. ALL 1.1 powered models used a 4.11. 1971: ALL 1.9 models, both MAN and AUTO, used 3.44 except for the Manta Rallye MAN which used 3.67. All 1.1 Kadett models used 4.11.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 06-26-2004 at 06:14 PM. |
Opelitis since 1984
Kalifornia Kid
RE:
"Good to see you posting either way. Your insight and knowledge would be really apreciated here if you have the time." Soon As I'm Done (Scanning 3000 Pages of the Blitz), I'll let you know.. |
No Access
Ok I'll voice my opinion yet again. Yippee wow thanks for a bit of the past and the promise of a good Opel future. If that is a hint you are taking over the OMC let me know where to join. You have pulled me out of the mess I get myself into and my support is completely there for ya. Please keep up the great work.
Just Dave in Colorados opinion Last edited by nobody; 06-26-2004 at 11:10 PM. |
