Does anyone know diff. bearing numbers?
Wheel bearings are no longer available from normal sources. OGTS is as competive as anyone on those. Seals are available from NAPA. I think one of the pinion bearings are available from NAPA, but the others are not. OGTS is probably your best bet. Make sure your mechanic has an Opel factory service manual and a proven track record on rebuilding differentials. This is a highly skilled process and attention to details is essential.
Pinion bearings, SKF 330865CQCL/C $59.45
SKF 330638CCQCL7C $42.57 from Motion Industries. Carrier bearings are the same as the 1978 Isuzu Impulse I think and are available from Autopartsgiant as a separate cup and cone set ($30). I have the numbers at home. I also have a source for the rear wheel bearings ($60) and have a NAPA number (at home) for the differential gasket. Will bring them tomorrow. Dave |
David, Thank you, thank you, thank you!
The complete set from OGTS is aprox. $400!!! This is why my mechanic, who by the way business name is action axles was shocked at the prices!!! He said he can get a bearing kit to rebuild o 1 ton trucks for about $150-$175 for everything and does so all the time!!! From what you quoted it would be at least half of OGTS prices.......Hell most wrecking yards sell complete rear ends for about $500 (not Opel GT) but other cars and trucks.
No problem. I'll have to make myself a note to bring the other numbers. The pinion bearings may be a bit more now, those prices are about a year old. If you need to order them let me know. I can at least steer you in a direction to obtain them.
Dave |
4ZUA787
yah i dont think im gonna need the gear set to rebuild it just yet but i jus wanna pull the cover off and drain the oil and look inside and what not so if anyone could throw out the number for the gasket for the cover plate i would appreciate greatly.
SPC Juneau |
PVCAR OGTS Sells the gasket, cheap!!!
OGTS P/N for the rear gasket (paper) is 7025 rear axle to backing plate in their current price list it's only $2.00 (cheapest part in the whole rear end)!!!
I'd call them @ 1800-673-5487 |
David a source would be fine, the P/N Important!!!
David
What I mainly need are the part numbers more than anything as my mechanic does nothing but suspensions, differentials and brakes!!! So this is his business and he can source out the parts he said as long as he has valid numbers and they will deliver to his shop!!! I will definatley make note of these numbers for future reference, for myself and others!!! thanks again, as I surely need to rebuild my differrental and stop the howling before I can feel safe driving the car anymore!!! I know for sure the right rear wheel bearing is smoked as it's leaking fluid and I might as well rebuild the whole thing while inside there since I have a willing and competent mechanic that can do so!!!
Calm down, Charles!
The bearing numbers are:
Differential side bearings: 19150 Tapered roller-Federal Mogul 19268 Race-Federal Mogul Rear axle 524169.Z27-FAG or RW105R Timken Differential housing gasket P-29076 NAPA If you're wondering about the comment, it's in reference to Charles Goin who is currently pestering me about something else. You are reminding me of him. It can get to be aggrevating. Good luck. Dave |
Hey Rick, how did it go with your bearing search? I'm thinking I should go with new bearings to match my BRAND SPANKING NEW 4.22 GEARS!
Hooray!! Huge thanks to Stan Czacki, what a guy!! Thanks Rick.
You've gotta PAY THE PIPER!!! OGTS
I got lucky and only had to replace the two outer bearings. The numbers posted are good numbers, however discontinued!!!
I took my car to a brake and suspension specialty place and he did an extensive search for the bearings from the Part numbers posted in this thread, good numbers no longer available here in the US. So you are stuck getting them from Gil!!!
Regards, Rick |
I have two or three new sets of the two side bearings and the two pinion bearings so I would be willing to sell, at a minimum, one set. Don't remember what I quoted Jeff Denton when I sold him the 4:22, but it is around $175.
Anyone who wants me to check, contact me and I will look this weekend when I am at the shop (100 miles north of where I work!) Stan Czacki, sczacki@utep.edu or 915-204-3520 |
I'll take them, thanks again, Stan!
Anybody have a guess why both my rear ends have the front (coupler end) pinion bearing looking scary, the rear (gear end) pinion bearing looking somewhat better, but the carrier bearings look good? Is there an oiling problem I should be addressing? As I plan to run a diff lube pump and oil-to- air cooler, maybe the cool oil should be dumped between the front seal and front bearing...
No Opels were harmed in the filming of this movie. However two Mustangs, a Pinto, and a Capri were hospitalized. One Mustang was euthanized the next morning. Last edited by jeff denton; 04-05-2005 at 12:55 AM. |
UK eBay
I got a set of Manta "B" diff bearings from "bearingsuk" on EBayUk for GBP78 - though with the exchange rate the way it is US/UK and with postage there probably would not be much difference from what OGTS charges. Just goes to show that Gil does a pretty god job on prices over there.
