Differential Rebuild
Fix one thing, find out more to spend money on!
The pinion bearings are about $180 from OGTS, plus a seal and crush sleeve that will be another $20 or so. This doesn't include the differential carrier seal, and the miscelleaneous bearings and seals at the axles. The early model bearings for the clip-in axles are not readily available either.
I think the bearings for the pinion are the same for all the years and models (GT/Manta). Your mechanic is correct, if the pinion/ring are worn, you'll need a new set. You might take the spare differential that you have, get him to check that and rebuild it, if need be. You could slide that up under the car and just bolt it up rather that mess with having the other one removed and put back in during the bearing replacement. Good luck, Dave |
All or Nothing
Crown wheels and pinions are always a "matched set" and lapped together before installation at the factory. So you cannot successfully just replace one or the other - especially 2nd hand ones that have further "worn" together.Swapping in a complete 1971 or later diff (that is in good condition!) is the easiest and most straight forward cure. Putting second hand parts from one diff into another would cost just about as much as installing new parts - less the cost of the parts.
However the early crown wheels AND pinion will fit - it is just the outer wheel bearings that were changed. Oh! And Isuzu Impulse gears and bearings will fit too ( but not the Isuzu outer wheel bearings ).
The guy said it would cost about 500 - 700 bones to rebuilt my existing diff. How much do you think I could find a good used one for?? Of course, I could end up in the same boat after $1000 miles. You say that the pinion bearings, etc are available. What about the actual gears?
New!
New gears are not listed by OGTS - I guess there must be some out there - somewhere. Never seen any on eBay either.
For $500 - $700 you would be able to find several complete 2nd hand diffs. The major problem to check for is loose pinion nuts - that is what causes most gear noise in lower milage diffs.
Gears come up occasionally on e-bay. I'd offer you some, but all the NOS sets that I have are 3.67 and don't fit the Type A differentials. That's probably about right on parts and labor for the repair. I'd just put that spare one in there and see if it works or is noisy. You could install it yourself and not really be out anything but labor.
No Access
This was something I've been thinking about, my rear diff isn't the quietest but is not in bad shape. I have another one in great shape but would prefer to just swap out the rear gears not the whole axle. I'ts not on the gotta do list but just an idea to maybe make it better.
Maybe I'll try the other diff..only problem is that is the older style. I just got in my order of rear polybushings, so I would have off the control arms and panhard arm anyway. I'm guessing just brake linkage, shocks, drive shaft and the torque tube cross member is all that left..and I have already removed these at one stage or another? I can also call Todd at Opels Unlimited, but I would guess shipping would be outrageous.
No Access
Or you could come get a builder housing the good axle bearings and axles less the gear set. your call you know where it is. It's a 73 and is very nice was on your right on end as you stepped into the shed. Then again I know of at least one more so let me know if I can help.
