Old 10-29-2005   #1 (permalink)
Part needed?
I'm DEFINITELY in un-charted waters here, as I don't normally deal with the inner workings of the differential. I had to change out the central bearing in the torque tube. There was a "button" that came out of the end that goes over the pinion shaft of the differential. It suppose to be on the end of the pinion shaft, but, mine looks like it has been loose for a while and has been bouncing rolling around for a while. I was wondering if this "button" is needed to re-assemble. I have attached a picture showing the "button" I need more knowledgeable advice on this.
Thanks,
Gene
Old 10-29-2005   #2 (permalink)
garrymc's Avatar
garrymc
Is that "button" the rubber bumper and metal "washer" that fits inside the splines on the shaft ? Should be 2 parts there like the picture shows.
garrymc is offline
Old 10-29-2005   #3 (permalink)
Yep!
Gene that wee button is the "thrust cap" - seems to be drawn twice in the illustration ...
If you look at the wee splined thingie on the front end of the pinion you will see that it is not parralell but is instead "barrell-shaped". Up inside the drive shaft itself at the inner front end of the spline there is a spherical area which pivots on the "button" as the driveshaft wiggles about a bit in the rubber "doughnut" at the other end.
So the button sets the longditudinal position of the drive shaft and is the bit that it pivots on - in short: "you need it" !
Where on earth do you get one is the next interesting question ......
Old 10-29-2005   #4 (permalink)
Killer Texas GT's Avatar
Smile From Me
Gene the detent cables I only have one good one out of four, so I can't help you there, sorry.
I don't have you mailing address on file, lost it during the updating process of the Texas Clubs Roster. PM me with it and the thrust button will be coming your way Monday. I hope that both the early and late model thrust buttons are the same this on is coming off of an early 70 model rear end from a GT.
If any knows that it does make a difference let me know so I can dig another one up for Gene.
rk
Killer Texas GT is offline
Old 10-30-2005   #5 (permalink)
wee button ...
wee splined thingie ......
Technical talk is SO exciting I just wish I understood more of it.
Old 10-30-2005   #6 (permalink)
Harold;
It's the accent he puts on the "wee" that really hits it.
