Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 4 - Propeller Shaft & Rear Axle > 4B - Propeller Shaft and Central Joint
Old 06-07-2007   #1 (permalink)
David McCollam
Unanswered: Interest in Getrag conversion driveshaft.
Recently, my struggle to have a driveshaft produced for my Getrag conversion led me down many paths. I currently have a location to have driveshafts with the correct slip yoke created. I presently have the parts to produce a couple of the driveshafts.
I have the correct measurements for the Manta/Ascona, but would need a measurement for the GT, if that's what you want. The cost on the complete item will probably be about $75-100, plus shipping. If I am able to get new OEM u-joints installed front and rear, it will be about $150-175.
Does anyone have any interest in a driveshaft like this?
Thanks,
Dave
David McCollam is offline
Old 06-07-2007   #2 (permalink)
Exclamation Getrag 240 driveshafts
Thanks,
Dave
Don't know what specs you have for the Manta/Ascona driveshaft, Dave, but how about this for both driveshafts!
Old 06-07-2007   #3 (permalink)
David McCollam
Manta/Ascona driveshaft length
Otto,
You got me again! The driveshaft length for my Manta ended up at 28 inches from centerline of bearing cap-to-centerline of bearing cap front-to-rear. I finally got one that works with new u-joints and all. It was so easy to install I thought something was wrong.
Dave
Old 06-07-2007   #4 (permalink)
Trouble Maker
Phoenix's Avatar
Real Name: Tony Holcomb
I would be very interested in one with new U-joints.
Phoenix is offline
Old 06-07-2007   #5 (permalink)
edca_opelgt's Avatar
edca_opelgt
measurements for the GT
Thanks,
Dave
This afternoon I made a driveshaft for the Getrag to be installed in my GT. Based on the measures I got from Otto and Gene (center weld to center weld is 9,75") makes 337mm center bearing to center bearing.
Eddy
edca_opelgt is offline
Old 06-07-2007   #6 (permalink)
Exclamation Drive shaft thrust spring!
Otto,
Dave
Uh, Dave, you DID remember to install the thrust spring inside the front yoke, right?!
Old 06-07-2007   #7 (permalink)
Lindsay
Driveshaft Yoke Damage
You DID remember to install the thrust spring inside the front yoke, right?
This is what happens when thrust spring is omitted!
Lindsay is offline
Old 06-07-2007   #8 (permalink)
No Access
I'd be really careful about posting a price before the first one is finished and all the hidden costs are seen. OGTS has the u joints but did you factor in shipping and any tools needed? Then again lock down a price for machine work. Now calculate the gas mileage to and fro and speculate on the price it will be when things are ready.
How many U joints are available?
Shipping cost for them.
so on and so forth
nobody is offline
Old 06-07-2007   #9 (permalink)
opelnut10's Avatar
getrag
Looking at the gear spread in that transmission I am glad I went to the trouble I did to install the T-5. That is a real stump puller first gear ratio then drops like a rock to second, nice if you are moving a heavy car but not so nice for using it for "spirited" driving on a winding road. Maybe if other gear choices were available it would be worth serious consideration. It a lot of money by the time you get everything you need to install in a GT, just to have an overdrive 5th gear.(IMHO)
opelnut10 is offline
Old 06-08-2007   #10 (permalink)
David McCollam
Driveshaft.
Thanks for the pointers everyone.
I'm new at this and have never really held a wrench before. What's a thrust spring?
Forget the driveshafts I'll let you guys get through it on your own. That's the best way to learn.
Enjoy the experience.
Old 06-08-2007   #11 (permalink)
opelnut10's Avatar
Thurst Spring
A thrust spring is a spring that is inserted over the output shaft inside the tailshaft housing. It's purpose is to keep tension on the driveshaft yoke and keep space between it and the speedometer drive gear, it also keeps the driveshaft yoke from wallowing around and beating the seal surface on the tailshaft seal and bushing.
Old 06-08-2007   #12 (permalink)
David McCollam
Is it a thrust spring or thurst spring? Wher did u say it goz? I dunt understand?
Otto, thanks for making everyone responding to this think I'm stupid.
Old 06-08-2007   #13 (permalink)
opelnut10's Avatar
Thrust Spring
I don't think anyone on this site is trying to make you look stupid, All of us gained the knowledge we have by asking questions and getting advice about things that we don't know about or wanted to learn about. As the saying goes "the only stupid question is the one you don't ask". I konw I am no walking book of knowledge but I have been around these cars since 1970 and for a lot of those years I had the good fortune to be able to be associated with a few people that had a lot more knowledge about them than I did and didn't mind sharing it.
Old 06-08-2007   #14 (permalink)
It also keeps tension along the whole driveshaft assembly, including keeping the other end splined section in contact with the differential input gear.
Old 06-08-2007   #15 (permalink)
Trouble Maker
Phoenix's Avatar
My uncle has been working on opels for quite a long time and got put through the wringer by his sisters when he was my age. He can tell you how many bolts are on x and what size head it takes, but every once in a while there's something that stumps him and he still learns new things all the time.
I myself am coming off the street pretty fresh, and learning not only about opels, but how cars work in general. I learn new things ALL the time.
Actually, when my uncle and I were putting the Getrag in the white wagon, we were bolting everything up and reallized that the Thrust Spring was still lying on the ground!
Phoenix is offline
Old 06-08-2007   #16 (permalink)
Red face NOT!!! my intent at all . . . SORRY!
David,
Thought you knew me better than that. Only meant as a reminder to everyone, not just you! Maybe I should have selected this rather than this . . . Anyway, SORRY!!
Old 06-08-2007   #17 (permalink)
guyopel's Avatar
Tony I have seen prof. mechs. leave flywheel off when installing engines and we all have a good laugh
and then hope we don't do the same thing It happens .. your thought process gets out of order , thats why it helps to write down on a install sheet and tag things to remind you to install or tighen a bolt if you have to stop on a project and return to it later. HTH
John
Guyopel
---Thomas Edison
guyopel is offline
Old 06-08-2007   #18 (permalink)
heimue's Avatar
OK, here it is: "Where is reverse gear?"
The "Getragiator"
heimue is offline
Old 06-08-2007   #19 (permalink)
heimue's Avatar
I did a little head scratching when installing my Getrag, since in the Getrag the thrust spring actually goes INSIDE the drive shaft vs. like described in the quote for the 4-speed.
Dieter
heimue is offline
Old 06-09-2007   #20 (permalink)
Talking . . . inside yoke . . .
Dieter
. . . which I'd already answered,
Originally Posted by tekenaar View Post
. . . remember to install the thrust spring inside the front yoke . . .
in post #6 . . .
Old 06-09-2007   #21 (permalink)
And then there is the infamous backyard mechanic I bought the SportWagon from who "rebuilt" a CIH but left the old rod bearing shells in place under the new shells
And then installed the clutch disk without the pressure plate
And then stripped a couple of valve train studs
OK, chill on the "thurst" spring. It's making me thursty.
Old 06-09-2007   #22 (permalink)
No Access
I was so happy when I put the 2.0 in the GT with the 240...until I backed the car up and saw this spring I special ordered from OGTS laying in the dirt where the car was parked. My personal best was putting 2 2.0s together and just before I put the heads on noticed the pistons were all facing the same way even though the motors were in opposite directions. If you never make a mistake it only means you aren't trying hard enough. Trust me, everybody screws up. It's how you handle it that matters.
nobody is offline
