Real Name: Gerry
Gerry |
Jerry,
I am not sure if they are the same but if you need a drive shaft, I do have an extra one that I am willing to sell only if it will work for you. Let me know you can email me at opelwrx.com just put my name first, rodney@_________.
doubtful
The engine on the GT sits further back than on the Kadett, I can't imagine the driveshaft would be the same. I could be wrong, but in order for them to be the same the 1.1 engine would be very far forward in the GT body.
Detritus Maximus
The parts book shows different driveshafts for GT and Kadett. The book shows no distinction between manual (c.t.) and auto (a.t.) for the 1100 GT like it does for the 1900 GT, but different part numbers for the manual and automatic Kadetts. So I presume that either the GT used the same shaft for both 1100's, or there were no automatic 1100 GT's, or the listing is inconclusive.
Trouble Maker
Real Name: Tony Holcomb
PrOpeller
(The reason I ask is because I am building another 1.1L GT, and I need to make a decision on which axle I should pick. Thanks!) |
1100 Gt
The replacement diff & gear set in the 1974 Parts Book show only 4.11:1 ratio.
I would not be surprised if in 1969 Opel started out with 3.89:1 gears (for economical running!) and later changed to 4.11:1 to get a bit more get-up-and-go from the small motor. GT1100 and Kadett1100 driveshafts are two different part numbers so probably different lengths - but the yoke splines will be the same so a Kadett driveshaft could be shortened for a GT.
#9 (permalink) | |
Dieter
