Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 4 - Propeller Shaft & Rear Axle > 4B - Propeller Shaft and Central Joint
Old 08-28-2008   #1 (permalink)
Unanswered: Proof the Opel torque tubes aren't that strong!
Found these pics on the German Hecktriebler forum. Ouch! Imagine if that let go on the highway instead of on the dyno.
http://www.opel-hecktriebler-forum.d...6_CIMG2718.JPG
http://www.opel-hecktriebler-forum.d...7_CIMG2720.JPG
http://www.opel-hecktriebler-forum.d...2_CIMG2721.JPG
http://www.opel-hecktriebler-forum.d...4_CIMG2722.JPG
Old 08-28-2008   #2 (permalink)
My God, Bob, that's scary. Wonder where the tube went. There's nothing shown of it except where it bolts to the differential and the forward mount. Any ideas on the cause?
Old 08-28-2008   #3 (permalink)
Apparently it had an aluminum outer torque tube, which are inherently weaker. So it probably disintegrated. But the center shaft is what broke it up. Harmonics are usually the issue, and when the center shaft 'whips' it strikes the outer tube. That is why for racing use they will either sleeve the OEM center drive shaft with a tube or make a new one from solid billet steel. It supposedly happened at 6500 rpms from what I could decipher with a 160 HP engine. I presume in 4th gear, as most chassis dynos are run in the gear that is closest to 1:1 ratio.
Old 08-28-2008   #4 (permalink)
I'm glad my dyno run only went to about 5400 RPM in 4th, and I think I've got a steel torque tube. I have noted a minor vibe at around 90 MPH, but I figure that's because my front drive shaft couldn't be balanced, it's so short. Another of the teething problems I've encountered, but an easy fix when I get "a round tuit", with a hose clamp rotated around the shaft until it gets back in balance. A trick I learned from the Gear Vendor folks when they installed one of their units on the motorhome.
Old 08-28-2008   #5 (permalink)
Can you say OUCH!!!!!!
Old 08-28-2008   #6 (permalink)
2 Fast 4 U's Avatar
OUCH!!!!!!
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 08-28-2008   #7 (permalink)
opelwasp's Avatar
Bob would cutting the shaft and welding the ends on to some driveline tubing prevent this from happening? I could get it done here for about $75.
opelwasp is offline
Old 08-28-2008   #8 (permalink)
heimue's Avatar
The drive shaft in the picture was obviously already reinforced. I got the same one, from Krause Rennsporttechnik (part # HA-00434, 120 Euro). Hopefully, mine holds up in the Kadett! They also have reinforced torque tubes (part # HA-00347, 83 Euro) for racing.
Dieter
heimue is offline
Old 08-28-2008   #9 (permalink)
1970-GT
Bob, looks like the maybe the pinion shaft bearings failed?
Or drive shaft out of balance, or U joint failure?
The rotating mass of a shaft at 6,500rpm's is nothing.
Something allowed the shaft to move off center!
Must be a case hardened shaft, sure bent alot, but didn't break.
WOW!
Lyle
Tru-Craft is offline
Old 08-28-2008   #10 (permalink)
Looking at the third pic, it appears the aluminum casting had a crack before the whole tube flew apart. Makes me believe this had been going on for a while. It's still a real scary scenario.
Old 08-28-2008   #11 (permalink)
dcm013's Avatar
dcm013
6500 RPM for that skinny little driveshaft is a LOT! The failure has to do with the driveshaft reaching critical speed and nothing to do with the torque tube itself. Critical speed is the RPM at which the shaft will reach its first bending mode and begin to go into resonance, where ultimate failure results. The torque tube actually prevented catastrophic damage to the floorpan.
It's the reason long wheelbase vehicles like pickup trucks have 2-piece driveshafts and/or large diameter driveshafts. Believe me, I had some first hand experience with this in my past automotive career
Here's an excerpt from the GKN website and a link to the site:
"Every driveshaft has a critical speed. Critical speed is the point at which a rotating driveshaft begins to bow off its
normal rotating centerline.
Driveshafts begin to vibrate as they approach critical speed. If they are operated at near critical speed for an
extended period, they often fail. This can damage the vehicle and possibly injure persons nearby".
http://www.gknservice.com/gkn-ids/re...ion_Guide1.pdf
Don
dcm013 is offline
Old 08-28-2008   #12 (permalink)
That aluminum casting certainly does appear to have been cracked for some time.
I wouldn't want an aluminum torque tube. My car has been roughed up a little, perhaps you heard about the time the left control rod bracket got ripped out of the floor? Leaving the poor torque tube to take the force of the left side of the rear end being shoved back. It held, but the bolts holding that flange to the diff sure didn't.
There's better ways to reduce both sprung and unsprung weight out back.
jeff denton is offline
Old 08-29-2008   #13 (permalink)
1970-GT
Don
Don, I agree a long, un-balanced drive shaft located with old/ worn U-joints and high twisting tourque loads could fail in time.
I had a Chevy truck that the U-jouint broke under a towing load, but it was old.
But a 150hp modified Opel motor driving a 2,000 lb car, through a short steel drive shaft, and a short steel pinion shaft and steel torque tube............no way!
Unless something was cracked, worn, damaged or un-balanced.
The rubber locating bushings in the torque could have been bad also.
If GM thought that the pinion shaft would fail at 6,500rpm they wouldn't have a redline of 6,000. I've had my GT to about 140mph/7,000rpm.
A well supported shaft could probably take 10,000rpm.......200mph in a Opel, Bonneville here we come!
I machine custom 5/8" diameter "soft aluminum" shafts varying in length from 2-3ft.
Machine rpm is above 4,000 with a cutting tool side load. They don't bend unless the tool pressure pushes the shaft off center.
For sure, something failed, the shaft was allowed to move off rotating center line, twisted under load and bent.
I am not worried about the pinion shaft failing.
Anyone racing a classic car should be checking parts for cracks, replacing all bearings, bushings and balancing everything.
Just my opinion.
Lyle
Old 08-29-2008   #14 (permalink)
Chris, I just weld some DOM steel tubing onto the existing torque tube. I remove the forward yoke, then chuck the t/t shaft into a crankshaft grinder. I grind a small step on the rear splined end to allow the tube (1.75" x .125" wall) to center itself on the t/t shaft. The forward section is tricker, but I get it centered via shims and weld it in one quick pass (after thorough tacking). Then a trip to the balancer is necessary (my friend lets me use his crank balancer), and weld on a few weights as needed.
Old 08-29-2008   #15 (permalink)
For hardcore racing, the steel IS the way to go. But mostly just for the cornering loads as a suspension link. In circle track, you will not see 7000 rpms in 4th gear! So the driveline speed is relatively low, therefore the t/t shaft critical rpms won't be seen in 2nd gear.
Old 08-29-2008   #16 (permalink)
If GM thought that the pinion shaft would fail at 6,500rpm they wouldn't have a redline of 6,000. Iv'e had my GT to about 140mph/7,000rpm.
You're correct in the sense that if all were perfect, there should not be any issues. Especially with a stock engine (which is all they were designed to handle) and rpm range.
But as you've also said, any variables otherwise can cause it to fail. A swapped driveshaft, a bad u-joint, a worn t/t bushing, or putting too much power into it. If for example, you hammered the car from a standstill one too many times, and put a 'tiny' twist into the t/t shaft, then the next time you run the car to 140 mph+ the rpms and the new t/t shaft imbalance can certainly cause an issue. The shaft diameter is small for sure, so there is little to keep in in line with the application of torque and rpms simultaneously. It will bow, and at some point the bow throws the balance off even more, and then failure.
Old 08-29-2008   #17 (permalink)
I'm by no means an expert on what ya'll are talking about here, but, I do know, from all my years of driving Opels, not racing, is that the cupped end, at least that's what I call it, the end that fits inside the diff itself, is in itself a weak point. In the pics of Bob's, you can see where the cup is split in several places. Now I don't know if that's what actually caused the whole thing to fail, but, I have pulled a few out of stock street cars that were split.
JMTCW
Old 08-29-2008   #18 (permalink)
1970-GT
Good eye BQS4, I rebuilt my torque tube 3-4 years ago, didn't see any cracks but wasn't really looking that close.
Like Bob said, the drive shaft/ pinion shaft assembly should be fine for our slightly modified Opel's. My GT see's 7,000 for about 10 seconds.
Even most SCCA classic racing Opel's wont see more than 135mph top speed, depending on the track.
The steel torque tube is a good way for the race Opel's to keep all the parts from flying all over the track!
For racing adding a tube is a good easy fix, not adding much rotating mass either.
Bob's Bonneville car won't be able to run the Opel setup, 9,000-9,500rpm sustained high load!? Depending on gear/tire circumference.
That Opel shaft will bend for sure.
Opel did a good job of keeping the parts light, strong enough and inexpensive.
Lyle
Old 08-29-2008   #19 (permalink)
Oh yeah? What if we were running the superspeedways like Daytona or Talladega?
Old 08-29-2008   #20 (permalink)
bello is on a distinguished road
Holy Flying Driveshafts!
OK You All, here is my version of the Gospel: Several years ago (1999) I was racing my Kadett at Daytona. As I learned the track, I started going faster & faster. Anyway, half way thru the weekend (3rd or 4th session) I was turning 81-8200 rpm in 5th (1.00:1) with a 3.90 diff gear. A vibration which I misinterpreted as tire balancing kept appearing just after Start/Finish- the end of the longest straight after the chicane- and eventually got scary! Had all the tires balanced- did not help. Two or 3 laps later, the SOB came undone, the shaft inside the torque tube- we discovered later- had been vibrating (out of balance) enough to "whip" its way to contact/hammer/crash into the torque tube. The rattling was strong enought to rip the center support bearing and housing off the floor mounts, broke the back of the TT off the nose of the diff, and sent the now-bowed shaft and sundry former drivetrain parts flying out from under the car! The motor, now unencumbered of all that drag, revved to at least 300,000rpms. OK but it was really high! Talk about being disconcerted! First the hammers of hell going just behind your butt under the car, then the engine speeds up as the car slows down...and you see all this shrapnel jumping out from under your car- into the path of the new best friends you have just made behind you! Later one of those guys stated to me, after I calmed him down, "...you haven't lived until you see a driveshaft tumbling thru the air as you close on it at 130mph..." There was talk of lynching me, but cooler heads prevailed, etc. Now the d/s center support is held in place by the bottom of one of the crossmember of the rollcage, with real reinforcements welded on= a 1/4" plate and welded in 12mm nuts & nuts holding the reinforced center support assembly tight. The splined shaft was ground as round as possible, then balanced on a crank balancer- Old John (Bob you know him) didn't think a shaft that small ID would need balancing till I told him of 81-8300 Driveshaft! rpms, then he became a believer as the thing tried to jump off the balancer! Now the thing is the best it has ever been. For what it's worth, in 23 years of racing this car, I have never split a shaft other than the "flyer" mentioned above. When Opels roamed the land, I fixed 3 or 4 Opels with splits shafts, but as I recall, on all of them the 4 bolts at the diff flange were loose! Being loose the TT and the diff were not perfectly aligned and were able to "rock" and now the shaft was more of a pipe that had side loads instead of torque loads: the "pipe" would split! Make sure your 4 bolts are tight!! Ernie Bello
bello is offline
Old 08-30-2008   #21 (permalink)
Lyle
Nope, already decided to run an 8" Toyota axle right from the start. Cheap, light, and I have one in my barn. No way I was going to run a torque tube at Bonneville!
Old 08-30-2008   #22 (permalink)
9000 or 9500 rpm then....
Old 08-30-2008   #23 (permalink)
You know, I never thought about that. Using the stock rubber mount in the stock bracket up at the front of the torque tube COULD allow a bit of rear diff wiggle in an awful hard left turn. I've got solid bushings in the panhard bar and control rods, but I wonder how much movement there could be coming from the front? Seems like Mr. Panhard should be taking almost all of the body's pull on the axle, yet a bit has to be acting on that rubber mount. Could it be worth "solidifying" that area? Trying to picture the forces at work here, any slop there should be causing understeer while the control rods are causing roll oversteer.
Old 08-30-2008   #24 (permalink)
A ton. It makes the axle rear-steer, but not in any predictable manner.
A few helpful tips:
*Use the heavy duty T/T front rubber mounts instead of the OEM smaller diameter ones.
*Get the OGTS heavy duty t/t donut. It's stiffer than the OEM and the factory h.d. donuts. Then, either back-fill the inside of the donut with a pourable silicone (P.I.T.A.!), or wrap a few pieces of old fan-belt around the donut via the holes in the t/t crossmember (cheaper and easy).
*Use the OGTS polyurethane upper and lower t/t bumpers. OR, use the upper poly bumper and do this to the lower: Weld a 1/4" thick plate to the t/t outer tube itself right above the lower bump stop was. You'll fit a 12 mm or 1/2" bolt to the lower 'shelf' inside the t/t crossmember as the new bumpstop, directly over where the lower bump stop was. I weld an 1/8" plate here with a like-threaded nut welded in place. The bolt threads from underneath and strikes the plate you welded to the torque tube itself. I round the end of the bolt over. Use a jam nut to holt it in place, and allow for adjustments. You'll want to apply a slight pressure to hold the t/tube to the upper bump stop, but don't 'force' it. This still allows for vertical movement and twisting movement but prevents the majority of slop. It's just a pivot point really.
Dave Jackson had a novel way to cure this tendency of the t/t to move, but it was by no means simple or likely cheap. Very creative however! He replaced the center bushings with a large bearing. Lots of rotation allowed, but ZERO slop!
Others have gone similar routes as mine, such as this. A chromoly shaft was made for the t/t inner shaft, and reinforcements made to the crossmember and the donut as well.
Old 09-01-2008   #25 (permalink)
I'm stuck on picture number one.
Mighty big exhaust tubing and I like the flange.
By chance is this a turbo car? Did it wheel hop on the dyno?
