Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 4 - Propeller Shaft & Rear Axle > 4B - Propeller Shaft and Central Joint
Old 02-07-2009   #1 (permalink)
standups's Avatar
standups is on a distinguished road
Answered: GT pops and lurches
is this normal something i have to get used to or is it a problem
“Work will win when wishy washy wishing won t.”
-Thomas S. Monson
standups is offline
Most Helpful Answer - Posted by ungermm
Check out this thread for a discussion and directions/tips on torque tube replacement. Post #15 has a photo.
http://www.opelgt.com/forums/4b-prop...rivetrain.html
Old 02-07-2009   #2 (permalink)
Links
Identifying the source of an Opel running problem, is a deductive process. Most likely suspects would be the ignition system (coil, wires, points, condensor) or the fuel system (fuel pump, vacuum leak, carburetor).
Articles on Opel tune-ups (dated June 2006), can be downloaded from links on the page below:
Engine
Anonymous D is offline
Old 02-07-2009   #3 (permalink)
Dennis Texas's Avatar
no it is not normal, check rear shocks or transmission /engine mounts
Dennis Texas is offline
Old 02-18-2009   #4 (permalink)
standups's Avatar
we found itit was the torque tube it wasnt bolted down does anybody have a photo of hwo it is supposed to be
-Thomas S. Monson
standups is offline
Old 02-19-2009   #5 (permalink)
UngerDog
ungermm's Avatar
ungermm is offline
Old 02-28-2009   #6 (permalink)
standups's Avatar
would a broken rear transmission mount make it clunk
and the bolts that bolt the torque tube to the bracket
what are they supposed to look like when done up
-Thomas S. Monson
standups is offline
Old 02-28-2009   #7 (permalink)
Certainly a broken mount would wreak all kinds of havoc with your drive train. The two pictures I found in my stash are of my car before the rebuild so they are pretty nasty, and the mount is torn on both sides but you can at least see how the whole thing goes together.
Old 03-06-2009   #8 (permalink)
standups's Avatar
can somone explain why the torque tube is bolted down if the rear suspension goes up and down
and if the bolts bolting the tube to the bracket are out would that cause the lurch
and why do the bolts keep pulling out
-Thomas S. Monson
standups is offline
Old 03-06-2009   #9 (permalink)
tomking's Avatar
well while the torque tube is bolted to the floor pan the tube itself is inside a flexible mount. Plus the drive shaft inside is carried in a rubber mounted bearing. It is built to flex.
TMK
tomking is offline
Old 03-12-2009   #10 (permalink)
standups's Avatar
any photos of tube mount to the body???
-Thomas S. Monson
standups is offline
Old 03-12-2009   #11 (permalink)
tomking's Avatar
Do a search here, there are several pictures of that in threads.
TMK
tomking is offline
Old 03-28-2009   #12 (permalink)
standups's Avatar
has anybody ever put a u clamp in to replace the torque tube bolts
-Thomas S. Monson
standups is offline
