Drive Shaft/U-joint Orientation
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
Like Tree2Likes
Thread: Drive Shaft/U-joint Orientation
    Senior Member My location zippy7575 is on a distinguished road zippy7575's Avatar
    Apr 2010
    Arizona
    806
    Cam
    When removing the driveshaft, what is the reason for making sure the drive shaft is re-installed with the same u-joint orientation? Is it because the drive shaft is balanced to work in one position only or because of how the the u-joint and yoke have worn together?
    I have a driveshaft vibration after replacing my torque tube donut, and it's better now if I put the driveshaft 180 degrees out from how it was before. Just trying to figure out why that is and whether replacing the u-joints would help or not. It's still vibrating a little and I'd like to fix it. Maybe it's just the heavy duty OGTS donut that's causing this?
    Sunburst yellow 1970 GT, 2.0L w/ header, Weber 32/36, Pertronix, Sway Bars, BWA Sportstar wheels. I've owned it since 1973.
    Kid at heart Frozen Tundra GT is on a distinguished road Frozen Tundra GT's Avatar
    Mar 2012
    Frozen Tundra
    5,117
    James
    both of your assumptions are correct.
    did you happen to replace the bearing too? did you evenly tighten the nuts? overtightening one side will make the ubolt lopsided. just a thought
    its easy enough to replace the ujoint, but hard to find one I think.
    Opeler Lindsay will become famous soon enough
    Jul 2003
    San Diego, CA
    2,182
    Wondering if a local shop can balance your GT driveshaft?
  5. #4
    2000 Post Club My location poor gt (R.I.P) is on a distinguished road poor gt (R.I.P)'s Avatar
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    U joints
    The u joints are a pain in the a$$ to replace, P.J. has a thread on how to replace w/ welded end stoppers. The original u joints are hot glued into place, no c clip as a retainer, you have to burn them out. Find a driveline shop, and they can balance the shaft, but they might have to make a holder for it, More $$$. I did mine about 4 yrs ago and used locktite 5 min. epoxy, that has a small self mixing tip, that can be put into the fill hole. The shop might be able to do a custom set up for you, u joints and balancing
  6. #5
    Member My location heliman is on a distinguished road heliman's Avatar
    Jul 2009
    Battlefield, Missouri
    473
    Check your U joints to be sure they are good and smooth, be careful that you don't overtighten the U bolts. If they are too tight it can bend the bearing cups and cause a vibration, also check your pinion angle. I have never seen an Opel yet that had a correct angle from the factory. Replacing the carrier rubber can make a change in the pinion angle from what it was with the old one.
    71 GT, Ford 2.0 Zetec, Jenvey throttle bodies, Omex engine management. Subaru 6 speed transmission , Ford 7.5 4.10 posi narrowed torque arm rear end. Coilover front end. Electric power steering. Honda Accord 4 wheel discs. In dash Vintage Air, Dakota Digital gauges. Power windows. Keyless entry. Cruise.
  7. #6
    Apr 2010
    Arizona
    806
    Cam
    Quote Originally Posted by heliman View Post
    How do you adjust the pinion angle? Via the front spacer washers where the center donut assembly mounts to the body?
    Better yet, how do you measure it and what should it be?
  8. #7
    Apr 2010
    Arizona
    806
    Cam
    Still got this problem and would like to get to the bottom of it. Ever since I replaced the torque-tube donut I've got a drive-line vibration. Turning the drive shaft 180 degrees from where it was before made it better, but it's still not right.
    I marked the orientation of the front drive shaft before I tore into it, but not the pinion shaft (inside the torque tube). Not even sure how you'd be able to do that as everything is hidden from view inside the tube.
    Still not sure how you adjust the pinion angle, so if anyone can shed some light on that I'd sure appreciate it. I have tried loosening the center donut assembly and making sure it is centered in the tunnel before I tighten it back down, but not sure this is the right way to go about it. It doesn't seem to make a difference in any case.
    Unless anyone has an idea of something I've overlooked, I'll just try replacing the U-joints and see if that helps. Funny that everything was fine before I replaced the torque tube donut though.
  9. #8
    Opeler Steve Daniels is on a distinguished road Steve Daniels's Avatar
    Aug 2005
    Ohio
    482
    Steve Daniels
    I have the same problem with my wifes red Gt. I used the heavy duty donut and have the vibration now. Turned the drive shaft 180 deg. made it better but still there.
    Steve
    1970 yellow Gt (Good girl)
    1970 red Gt (Ozz)
    1969 silver Aero Gt (Oscar)
    1969 Green Aero Gt (Crispy)
    "You have learned much,young one"
    "Your destiny lies with me"
    "It is ussless to resist"
    "There is no excape"
    "You have only begun to discover your power"
    "JOIN ME.... AND I WILL COMPLETE YOUR TRAINING"
    With our combined strength,we can end this distructive conflict and bring order to the OPEL GALAXY
    If you only knew the power of the ....
    OPEL SIDE
  10. #9
    Apr 2010
    Arizona
    806
    Cam
    Quote Originally Posted by Steve Daniels View Post
    Steve
    I wonder if the heavy-duty donut is really the problem? Anyone else using the HD donut got this problem?
  11. #10
    άber Genius My location First opel 1981 will become famous soon enoughFirst opel 1981 will become famous soon enough First opel 1981's Avatar
    Apr 2003
    Portland, Oregon
    6,286
    FWIW... My son did the donut on his GT (I think it was the HD one) and had the vbration as well. He said it was BAD bad.
    Rotated the U-joint made it a little better but not right. He removed the yoke from the pinion shaft, rotated it 90 degrees, and it's smooth again.
    This thread was the inspiration for the "fix". We figured the worst thing he'd have to do would be to move the yoke one tooth at a time but the 90 degrees was the trick.
  12. #11
    Apr 2010
    Arizona
    806
    Cam
    Great info, thanks!! Were you able to do that with the torque tube and donut assembly still in the car? I seem to remember that getting that yoke off the shaft was not easy.
  13. #12
    Apr 2003
    Portland, Oregon
    6,286
    Quote Originally Posted by zippy7575 View Post
    The yoke was easy to remove from his car. And, you don't have to do anything to the donut. Just remove the rear of the driveshaft, remove the giant nut, pull the yoke off, rotate it 90 degrees, reassemble.
    I think we tried three configurations and it took about an hour.
  14. #13
    Apr 2010
    Arizona
    806
    Cam
    Awesome! I guess I know what I'll be doing tomorrow.
    Do you really mean 90 degrees, or 180? Of course, it might not be the same on my car, but I want to try what you did first.
  15. #14
    Site Founder My location Gary has a spectacular aura aboutGary has a spectacular aura about Gary's Avatar
    Swansea, MA
    8,826
    Gary
    4
    I do.
    www.alt-opel.us
    @opelgary
  16. #15
    2000 Post Club Site Supporter My location P.J. Romano will become famous soon enough P.J. Romano's Avatar
    Aug 2006
    Goderich, Ontario Canada
    2,540
    P.J.
    There are two large spacer (shims) between the donut supporting bracket and the car body (floor). They are often missed but are important to properly line-up the drive shaft.
    Check that they are there.
    Tip: Replace 2 bracket 15mm bolts with 10x50mm s/s studs. That will make reinstallation of the bracket way easier and will prevent striping the thread of the nuts welded on the car body. Use some threadlock to keep the studs from turning.
  17. #16
    Apr 2003
    Portland, Oregon
    6,286
    Yes. I mean 90 degrees.
    THe U joint can only be oriented in 180 degree increments so I figured that if neither one of those orientations worked then you have to think outside the 180 degrees. How far out can you think than 90?
    But there are about 20 (or however many splines) different orientations you can try. Try 90 first.
    opelgt722002 likes this.
  18. #17
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    I'm running the HD donut tube from OGTS, and glad to say no problems, I had to even install a different drive shaft , due to the shop had lost the end caps off of the newly installed u-joints in the driveshaft that I took them to balance :banghead::banghead: got it back 3 mo. later, with smaller caps, but at least they were able to balance it, and didn't charge me a thing. Plus I have an extra set of caps , but I wasn't going to tell them that
  19. #18
    Apr 2010
    Arizona
    806
    Cam
    Makes sense. I'm excited to have something new to try. This has been eating at me for a few months now.
  20. #19
    Aug 2006
    2,540
    P.J.
    Heavy duty donut will not cause the vibration. It will only transfer more of the existing vibration to the body as it is harder than standard donut.
    RallyBob likes this.
  21. #20
    Apr 2010
    Arizona
    806
    Cam
    First Opel's suggestion seems to have been the fix. It's not perfect, but it's the best it's been. Without trying each and every spline on the shaft (which means removing the yoke every time) it's going to have to do. It probably wasn't Lexus smooth to start with anyway.
    I tried moving the yoke 90 degrees first, which made it worse, then went another 45 degrees, which made an improvement. Each time I moved the yoke I would also try flipping the drive shaft 180 to see if one way was better than the other.
    Thanks to F.O. for the tip!
+ Reply to Thread
  1. [WTB] Drive shaft for automatic GT
    By alolmo in forum Opel Ad Board
    Last Post: 12-22-2009, 03:05 PM
  2. Steering shaft U-joint
    By blancojp in forum 3B - Steering: Linkage, Column and Gear Box
    Last Post: 04-18-2008, 10:18 PM
  3. drive shaft....
    By bosco in forum 4B - Propeller Shaft and Central Joint
    Last Post: 01-28-2004, 04:44 PM
  4. Help Pulling Drive Shaft
    By CDN OpelNut in forum 4B - Propeller Shaft and Central Joint
    Last Post: 10-30-2003, 01:04 PM
  5. Drive Shaft?
    By namba209 (R.I.P.) in forum Engine Swap Forum
    Last Post: 09-26-2003, 01:32 PM
