Unanswered: SD1 Axle
Now, I'm ready to work on my rear axle !!! So, I want to use a Rover SD1 axle as you know. A guy told me a need a SD1 VItesse one, but the ratio is 3.08:1...it's to long for a 6 speed gearbox. I know the 2400 TD and 2000 manual have a ratio of 3.90:1, but I don't know if I can use them...if mecanicaly it's the same! regards
Marc, The VW killer |
i think the outside is the same marc apart from the diff cover on the LSD is bigger and the brakes
i have still beem looking for one here for you but with no luck so far ![]() i will have my van on the road in a couple of weeks and will have a look again to see if any have turned up over the last month
Hi Baz,
so I can use it .... I shall make an order to 'Rimmer Brothers' in England unfortunatzly, they are very expensive...If you know a shop where I can buy it , please tell me.
Many Made
Here is some info about where they went to new:
Only a few months later, in April 1982 (and only for export at first), the 2400SD Turbo version was also introduced, this using a 2.4-litre turbocharged diesel four-cylinder engine, manufactured by VM of Italy. Aimed specifically at certain European markets, this was a 'tax-break' model for those markets like Italy which put operating economy ahead of performance: although the engine only produced 90bhp, it produced lusty torque, a top speed of 103mph, and fuel economy of better than 30mpg. Automatic transmission was never available in the diesel-engined car. SD1 Production Figures: 1976 - 1986 Rover have never been able to provide completely detailed production figures Choosing from several Rover sources, these are the approximate production figures for every significant model: Four-cylinder types: 2000cc 20,554 2400SD Diesel 10,081 Six-cylinder types: 2300/2300S 42,996 2600/2600S family 108,572 V8-cylinder types: 3500/3500SE/3500VDP 107,916 V8S 1,040 Vitesse 3,897 VDP EFi 1,113 Total of the above 296,169 Nevertheless, when all CKD assembly is considered Rover state that a grand total of 305,139 cars of this type were produced in ten years. A big search - but there must be a few parked behing motor shops around Europe still. Here is a Rover Diff in a Manta: http://www.mantamagic.com/v8manta4.htm List of the modifications: http://www.mantamagic.com/modifying_...sse_axle_f.htm
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 09-05-2006 at 07:57 AM. |
Expensive??
You don't need the axles for your GT conversion and that price is for 3.90/3.54/3.08/2.84 - any ratio you want. You will need a torque tube though. Fot an extra GBP667 you can have a Quaffie Limitied Slip Unit included .... Here is a diff on eBay.UK: http://cgi.ebay.co.uk/MGB-Axle-Rover...QQcmdZViewItem A bit 'cheaper' but unknown condition and who knows how many kms ?? GT diff rebuilds are not inexpensive - GBP1,500 plus range for a full rebuild - at least!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 09-05-2006 at 10:18 AM. |
marc that is not to far away from me if you bid for it , i could drive down and pick it up (2 hours each way ) then meet up at a later weekend as we talked about in kent
Thanks for all guys!
I shall make an order to Rimmer, but to be sure, here is my last question: I can buy axle with the followed ratios: 3.08:1 or 3.84:1 or 3.45:1 or 3.90:1 Here are the ratios of my 6 speed gearbox: 1st: 3.827 2nd: 2.360 3rd: 1.685 4th: 1.312 5th: 1.000 6th: 0.793 what is the best axle ratio I have to use ? of course to keep the car FUNNY!
Similar Dilema
3.90 X 0.793 => 3.1 effective diff ratio in 5th gear overdrive
3.54 X 0.793 => 2.81 effective diff ratio in 5th gear overdrive I tend to think that with the GT 3.90 (3.1 effective) would give a higher actual top speed than 3.54 (2.81 effective) which may be just a bit "long" for our tiny motors - even 2.4L ones! There is - somewhere - a method of working out 'best' ratio using engine power, car weight, tyre diameter etc. etc. .... must see if I can find it again .... HTH PS: I am using the 3.89:1 gears from an Isuzu Piazza (Impulse) diff - but have the original 3.44:1 GT ones there if they prove too "short" and I need more "legs" Whateva - the GT will be a demon off the line in the lower gears with 3.9:1
Ok, it's done I've made the order today. Iy will be a 3.90:1 rear axle.
The maximum speed with my 6 speed gearbox, will be +-205 km/h Baz, the shipment price is not to high so Rimmer will send it to me. regards friends.....
ok marc i will remove a SD1 axel from the hunt list , so one is bound to turn up next week
