axles
Gary;
I don't know how it could be done, but, I have a set of axles, but, I'm here in GA. If you can't find anything, let me know. Gene
I shall measure the length of an Impulse axle tomorrow as there is one out and on the workshop floor beside the Isuzu diff housing. The measurement from the end of the spline to the inner side of the bearing is the critical one.
Site Admin
The Isuzu Impulse diff is 1440mm or 56 3/4" wide from wheel mounting surface to wheel mounting surface. That should give some idea of the axle length compared to the Ascona.
I think that it is a 1/2 in bigger than a manta rear end. Opel Racer Stan C told me that. I do believe that the manta and ascona rear ends are the same.
wider is better... but you have to use 14 wheels. c |
#10 (permalink) | |
The non turbo one has 3.89 gears if you can find one |
Possibilities
As you already have the Impulse diff you have two choices:
1) Install the whole Isuzu diff - it may be marginally wider than the Ascona one but they have been fitted to GTs which have even narower originals. 2) Since your Opel diff has no axles just remove the gear cover plate and slide an Impulse axle into the Opel diff and see how far the splined end sticks into the diff carrier. It may fit without even shortening the axle. BTW: The diffs from 4-speed auto Isuzus have limited slip diffs here .... but apparently not over there. Also the complete Isuzu 3.9:1 gear set and carrier will fit into the Opel housing.
