#26 (permalink) |
[that wasn't the last engine, the most recent spun a rod bearing in september]
1970 Opel GT 1.9 1980 Moto Guzzi V50 2000 Saab 9-3 2.0 turbo 2000 KTM 200 exc STOLEN Last edited by jordan; 11-07-2008 at 10:06 PM. |
#27 (permalink) |
Opels Forever
Real Name: Cliff Carlson
That's a good idea. I'm also having trouble with my temp. gauge, I can't tell for sure if the reading is correct. I'm thinking of getting an aftermarket gauge cluster to install as a temporary fix, just so I can monitor the vitals while I'm working.
1969 Opel GT (owned since 1985- under restoration) 2004 Pontiac Vibe (wife's car) 2005 Chevrolet Avalanche 1500 4WD 1994 Mercury Villager |
#29 (permalink) | |
The VDO OP sender's ohms resistance range is specified as 10-180 ohms, i.e. 10 ohms minimum reads 0 BAR/PSI and 180 ohms maximum reads 5 BAR/80 PSI. ANYTHING outside of the 10-180 ohm reading on the "gauge" wire, i.e. short/zero ohms or open/<180 ohms will cause the OP gauge needle to peg! . . . ask me how I know! . . . this is also why the OP gauge needle "jumps" slightly when you first turn the ignition key "on" . . . current flow through the OP sender's minimum 10 ohm resistance.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 04-05-2009 at 07:04 PM. |
#31 (permalink) | |
Uber Genius
You don't have to take the carb off to change the oil pressure sending unit. It would make it easier to change it if the intake/exhaust manifold were not there but it can be done with everything in place. The easiest way is to go up under the car and snake your tools through the exhaust. Its a pain but doable. It might help if you bend your wrench as needed to make it work.
#32 (permalink) | |
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 04-06-2009 at 03:20 PM. Reason: change from 17mm |
#35 (permalink) |
Army Opeler
well, i ended up taking the carb out which really helped. i just couldn't see going up through the bottom. i can get my hand on it easy enough but hard to get a tool in there. did you say it's 17mm? i've tried 18 mm and 3/4 to get the old one out but they didn't seem big enough.
#36 (permalink) | |
#37 (permalink) | |
Opel Addicts
1) What is the proceedure to bench test an oil sending unit? (Before I get chastised, yes I did spend an hour using the search function on this site). 2) Gene - what part number on the egauges.com site did you order? I want to try to get Opie's 2.0 up and running, but I want to be sure that the oil pressure gauge is reading accurately. Thanks for your help guys (and girls)! Allen Gage
1958 Rekord Olympia Newest Acquisition 1969 Kadett LS Odette Showroom New Original 1969 GT Omi The Grandmother 1970 GT Octavia Streetrod 1971 GT Opie DESTEC car 1972 GT Olessja Under restoration from being rear-ended 1973 GT Oscar Awaiting Restoration 1975 Manta yellowOmaryellow The Bumblebee 1975 Ascona Sport Wagon: Otto Colonel Mustard 2008 Solstice yellowOliver - "Ollie"yellow |
#38 (permalink) | |
. . . and this is the correct "egauges" adapter to adapt the OP sender male 1/8NPT fitting to the block's female M14x1.5 threaded OP hole, P/N R7963
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-02-2009 at 08:59 PM. |
#39 (permalink) | |
Harold |
#40 (permalink) |
Opel Addicts
Otto and Harold:
Thanks guys..... just the information I was looking for! Allen
#41 (permalink) | |
Bob Last edited by SpringGT; 07-02-2009 at 11:45 PM. |
#42 (permalink) |
Opel Addicts
That sounds like it would be a good way to go. I'm assuming I can find an adapter somewhere that would work. Thanks for the suggestion.
Allen Gage
#43 (permalink) | |
Harold Last edited by tekenaar; 07-20-2009 at 03:47 PM. Reason: gitter? |
