thescifiguy
Real Name: Gordon Payton
Unanswered: Pre-war engine?
So, do I have a 1930's-era engine?
Trouble Maker
Real Name: Tony Holcomb
19s means its a 1900 CIH engine.
They were first produced in 1968. Everything else was either smaller or OHV.
Dipstick local
The dipstick may be in the back of the pan on the opposite side by the oil pressure sending unit-that would be a 68-9 pan. Will have small loop style handle-wonder why they moved them, try to get to it in the car-well on a GT it would be tough
Keith
www.opelgtworld.de
Is this only a stupid question ?
Or is it only ignorance? Sorry, but I do not think that this is particularly brainy or funny...
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)" Last edited by Gary; 05-06-2008 at 06:37 PM. |
GTer
Real Name: Patrick
![]() Please, change these thoughtless words or let one of the moderators remove this thread.
Definitely EX-member of the MWTE! © Mr. Corey Suggs |
thescifiguy
Sorry
Dumheit muss bestraft werden ("Stupidity deserves punishment" or something like that. My mom's favorite quote.) Pardon the spelling is it's wrong.
My apologies to anyone who was offended by my mild attempt at humor. Yes, the dipstick is short, folded over, and located near the oil pressure sender. The year on the engine wouldn't be underneath or behind the starter would it? Are there dates also on the cylinder heads somewhere(in case that's been changed also)? What sorts of specifications would be different on this engine that were changed in later years?
1971 GT
Corey
CIH History ...
The history of the development of the Opel CIH engine, 1966-1993.
The motor type was designed in the early 1960's. Opel's Camshaft In Head engines were introduced in 1966 with the Opel Rekord B and Kadett B, soon finding their way into Rekord C, Opel GT, Opel Olympia A, Manta A and Ascona A. With this new engine Opel began a new era within motorsport, which started well with the Swede Lillebror Nasinius' championship win in the Eruopean Touring Car Rally of 1966, driving a 1900 Rekord B. The CIH motors were initially available as 4-cylinder 1.5 - 1.7 or 1.9 litres, or the 6-cylinder engine available as 2.2 litres in the Rekord C for a very short period of time, and then were available as 2.5 and 2.8 in the Commodore A, Kapitän and Admiral. When the Rekord C Sprint was marketed in 1967 a sporty version of the 19s engine featuring 2 vertical Weber DFO carburettors were put into production, and the engine was also fitted to some Kadett B's for the foreign market. (hmmm - I wonder about this ... source may be confusing it with the dual carb 1.1L motor??) Hardly Pre-War ... unless you are talking about the 1st Gulf war ... Date codes on Opel castings are a little hard to decipher since we have so little information from the factory - but there are a pair of numbers cast on most heads that do indicated year of casting (and, perhaps on cylinder blocks also). Finding anything before 1965 ( or '65') would be a surprise though!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by tekenaar; 05-07-2008 at 12:43 PM. |
#9 (permalink) | |
Sprint Option
I also believed that the Rekord Sprint engine was designated as a 1.9H engine
May be mixing it up with a 1.9H head. I will have to look, or Otto may recall on that. Keith
. . . in a word, CORRECT! 19H-heads, actually 19HL-heads, were cast with revised combustion chambers (9.5 CR) and special intake valve springs with 'closed' pressure raised by 5kp (33-38) and 'open' pressure raised by 9kp (57-66). 19HL-head cam specs, valve sizes and exhaust valve springs were identical to those used in the 19S engines.
thescifiguy
Where's the 19H?
Okay, so where would I look on the head to find the 1.9S or 1.9H? Would that also be under the valve cover somewhere? Whereabouts would the casting date and other ID be under there?
This engine is the most ferocious sounding 1.9 GT engine I've ever owned. I've had 3 previous 9:1 compression engines and a 2L big valve and this baby sounds a lot like the latter. Also, on the driver's side of the engine, there's a nickel-sized round plug or emblem near the timing chain cover that says: "Guaranty Void If Removed". Is this an indicator that the motor was rebuilt? The motor is painted baby blue if that's any help. Crossing my fingers.....
#14 (permalink) | |
19HL head uses same size valves as 19S head though . . . as I said.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 05-07-2008 at 09:45 PM. Reason: add info |
#16 (permalink) | |
![]() There are two types of engines: N and S
