Old 05-09-2008   #1 (permalink)
jak133's Avatar
jak133 is on a distinguished road
Unanswered: GT Engine Tilted?
just had engine and trany rebuilt is the engine supposed to tilt to the left?
jak133 is offline
Old 05-09-2008   #2 (permalink)
in a gt yes
its to help with hood height
Old 05-09-2008   #3 (permalink)
Right?
It tilts left, depending on where you are looking from.
More clearly, it tilts so that the passenger side is lower then the driver's side.
This is done with motor mount top brackets (which are side-specific), and the trans mount bracket.
Anonymous D is offline
Old 05-09-2008   #4 (permalink)
jak133's Avatar
then its right or left either way its tilted correctly
jak133 is offline
Old 05-09-2008   #5 (permalink)
opelspyder's Avatar
Motor mount brackets
No, the tilt is built into the engine cradle itself on a GT. There should be two spacers from the factory between the inner frame and the engine cradle. The one tower of the cradle is taller than the other one, to create the tilt. Yes the top engine brackets are different, but not in height, but in length. The way to tell them apart is the drivers side has a small "dot" right next to the engine mount bolt hole. There is a thread with pictures on this as well-may be in a restoration thread.
Keith
opelspyder is offline
Old 05-09-2008   #6 (permalink)
Yep - GTs Tilt (At windmills ??)
The carb side of the motor is lowered to fit the air cleaner bend under the hood - Opel still had to put that nifty 'bump' there for clearance though ...
It is about 14 degrees away from 'plumb' (or maybe 7 degrees?)
Old 05-09-2008   #7 (permalink)
heimue's Avatar
It is wayyy less than 14 degrees. I don't know the exact value, I estimate around 3-4 degrees, definitely not more than 5 degrees.
Dieter
heimue is offline
Old 05-10-2008   #8 (permalink)
When looking at the engine its right or left
BUT when your working on the body its from the drivers seat completely the other way around. Got to love them the #$#&^%$#^%n wipes.
Old 05-10-2008   #9 (permalink)
Maybe just to make it easier on everyone, use the standard used in the aircraft/military industry. Everything is based on sitting in the pilot's seat when referring to left/right/port/starboard.
Old 05-10-2008   #10 (permalink)
West Coast GT's Avatar
West Coast GT
Does the engine tilt the opposite direction down under, seeing as how it's in the southern hemisphere?
West Coast GT is offline
Old 05-10-2008   #11 (permalink)
Well .....
For a start the driver's side is the wrong side instead of the right (hand) side!
