Unanswered: Cleaned up my fuel and vacuum lines...
Jet Wrech |
Actually, the large hole is for air to go in to the valve cover, from the air cleaner housing and the smaller hole is for a metered oriface to the intake manifold. HTH.
#3 (permalink) | |
Big Hose
But when the engine is at an idle, and if there are less crankcase vapours being created than the vacuum PCV is pulling out of the valve cover, the large hose actually lets filtered air INTO the valve cover, preventing the crankcase from being pulled into a vacuum. Exactly the same function as a "breather" oil filler cap, but ensures that air entering the engine has passed through the air filter before it is circulated through the valve cover on the way to the PCV metered orifice
Just a question to put out there.I didn't think we used a pcv valve in our cars. At least not in my 71.With that hose off the car stalls all the time & just doesn't run that well.Had to JB weld a proper fitting to the cover to get the hose to stay in properly.
Thanks for the replies! There are no input ports on...
Redline air filter (probably an aftermarket cleaner assy) I could modify the air cleaner to accept the line from the valve cover, but I would rather not to keep it original. Thanks again for the input! The website is a valuable source of information!
![]() ![]() Jet Wrench |
#8 (permalink) | |
I thought so.Got confused when jetwrench was talking about his pcv valve on his gt.Was in a car show up at Qualicum up Island here last weekend.Incredible ,Around 600 cars.I was the only Opel.Lots of interest & stories.
For years I ran a hose from the large opening to the ground with no adverse effects. However, if you do that keep an eye on the possibility of sludge buildup in the engine. One primary function of the PCV system is to purge water vapor from the engine, and without it the oil will become contaminated. You can see the milky emulsion if you remove the oil filler cap. Be sure to follow good oil maintenance schedules.
Venting to the atmosphere is not the environmentally responsible thing to do, and now my Opels are properly vented to the air cleaner. No, it's not the ideal situation for performance, but most of us probably won't notice the difference. One side benefit of venting the PCV hose to the air cleaner is that maintaining a partial vacuum in the engine will reduce oil leaks! Bill |
Mid-West Opeler
If you can't feed it back into the carb you can find a breather filter at NAPA.
Napa air breather
In sawdust's photo on the 6-17-08 thread on the napa air breather, where does the breather vent to, and also it is hard to see where the smaller hose also leads to. It looks as though it T's to another line. I have a 69 gt and am still trying to finish up all the vacuum lines among other things. thanks for any help you can provide. Bruce
Mid-West Opeler
The red breather vents to atmosphere.
The small vacuum line does 'T' to another line going to the base of the carb. fwiw..
Real Name: Craig Roberts
Targa/ F/I hose connection
I'd like to hook up both valve cover hoses on the Targa properly.. they currently vent to nowhere.. I guess a T for the large hose and running the small hose to the intake manifold where I found a place for it that is currently capped.
Any reasons why I should not do the above?
Craig Roberts |
Mid-West Opeler
You can always undo it if it does not work
