Opel Forums
Go Back   Opel Forums > Technical Forums > The Main Tech Forums > Group 6 - Engine > 6A Engine Mechanical
Old 10-05-2008   #1 (permalink)
pro0846 is on a distinguished road
Unanswered: Engine Seized...Help!!!
I just bought a 1970 Opel gt. my plan is to restore it, the body is in great shape, electonics work great, everything is perfect... except the engine is stuck from sitting in a barn for so long...... any ideas of how to unseize the engine?
Last edited by tekenaar; 10-06-2008 at 11:20 AM.. Reason: baught, perfict, unsieze
pro0846 is offline   Reply With Quote Top home
Old 10-05-2008   #2 (permalink)
Originally Posted by pro0846 View Post
I just baught a 1970 Opel gt. my plan is to restore it, the body is in great shape, electonics work great, everything is perfict... except the engine is stuck from sitting in a barn for so long...... any ideas of how to unsieze the engine?
One thing to try, before going onto harsher methods, is to grab a 19mm wrench, or a 19mm socket with a pull handle, and see if the motor will turn over by hand. Remove the spark plugs first, and if it's a manual trans, put it in neutral, or if it's an auto, just pull it out of park, to make it easier.
Old 10-05-2008   #3 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Search for "siezed engine" and "seized engine". Here is a link to a pretty good thread:
http://www.opelgt.com/forums/6a-engi...html#post30545
Matt
newman27 is offline   Reply With Quote Top home
'72 Opel GT (Fireglow Orange)
Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars
Restoration Thread
Comments Thread
Other Cars:
Old 10-05-2008   #4 (permalink)
opeletti75 is on a distinguished road
engine needs
i have good used high comp engines for sale for 300.00 if interested
opeletti75 is offline   Reply With Quote Top home
Old 10-05-2008   #5 (permalink)
UngerDog
ungermm's Avatar
I would disconnect the fan belt first. I've seen what appears to be a seized engine turn out to be a seized water pump. If after removing the belt the engine is still frozen, you can remove the plugs and squirt some mystery oil or other light penetrating oil into the chambers. Trying to get a 19mm wrench on the crank with the radiator,shroud and fan still in place is very difficult. So instead, if you have a manual transmission, put it in 2nd gear and rock the car to see if the engine will rotate. That's if the brakes haven't seized.
Jerry
ungermm is offline   Reply With Quote Top home
Old 10-06-2008   #6 (permalink)
OpelJim
great advise can you come down south and help out
Jerry
Jerry,
Can always employ a good Opel mechanic down here in Lake Elsinore!!!
The lubricant of choice here is PB Blaster works great at getting rusted parts "broken"
Jim
OpelJim is offline   Reply With Quote Top home
Old 10-06-2008   #7 (permalink)
Jerry's suggestion on the water pump makes sense, so I'd try that one first. Not working I'd move on to removing the plugs as others have suggested and squirt you're favorite rust penetrate in the spark plug holes and rock the car in gear as I believe it will have more leverage than a pull handle and socket on the crank. You probably won't mess up the crank bolt but... If it doesn't break loose close the hood and try it again another day(s). Patience!
Old 10-07-2008   #8 (permalink)
cherokee's Avatar
cherokee
You might want to get a look inside and then make a choice how far you want to go. I have a car (not and Opel) that sat inside a barn that was climate controlled for over 20years. The engine was locked up tight. I pulled the water pump and it looked like lava in there. I decided a rebuild was the only way to go.
Just something to think about.
cherokee is offline   Reply With Quote Top home
