Real Name: Ruben Van der Beken
Answered: 2.0 L cylinder head
I would like to mount a 2.0L cylinder head on the 1.9L engine block of my 1970 Opel GT. The machine shop told me that a 2.0L head doesn't fit on that engine, because it doesn't have the two M8 bolts. Is this correct? |
Most Helpful Answer - Posted by deaner
| The 2.0 head will work with your 70 1.9. Just use the 70 head gasket. As stated before the extra holes were for the timing cover. It's a matter of matching the correct head gasket for the timing cover. You should be ok. No need to change timing cover. |
Incorrect information
The 2.0L head will fit on the earlier style 1.9L engine block. The two extra bolt holes on the cylinder head are for the timing cover. If you change the timing cover to a later model 1.9L '73-75 cover or a 2.0L timing cover there will be the two bolt holes for the 2.0L head. You should also used the later 1.9L head gasket with the correct thickness front edge for the 2.0L cylinder head.
Good luck, Dave |
long time Opeler
long time Opeler
I use Permatex Aviation gasket sealer around the front. Let it tack up as per instructions. I've done this many times with no leak. Do not use silicone sealers.
