Unanswered: How easy should it be to rotate the bottom end?
1972 & 73 Opel GT. 1972, 73, & 74 Saab Sonett. 1996 Taco. 1996 Accord. |
Have you checked your rod bearing clearance?
Also you may have a bent rod, or two or three or four, which can tighten things up drastically. A short block assembly should turn over easily with a 12" long wrench on the front pulley bolt. Twice during each revolution it should be real easy, as two pistons are rolling over at TDC and two are rolling over at BDC. So called rebuilt engines are the scariest, need checked over real good. You don't know what kind of knucklehead put the thing together. Huh, Joe?
Dallasmanta
Real Name: Ron
Reading your post you do not say that the rods were connected in this exercise so my educated guess would be a bent crank shaft or one that has a bearing that does not match the crank machine surface. Did you check the brearing compressed clearance when you re assembled the lower end..
Reasons for bent crank shafts are storing them laying down vs sitting on the fly wheel end. Improper machining / matching of the bearings to the crank shaft. Hope this helps. Ron |
No....its not a Buick....
Silly question here,but you are tightening the caps down in the correct sequence right? Joe
Just a couple of question for ya: you are priming the oil pump before trying to rotate crank? When you assembled the engine after machine shop loosened up your pistons you did lube the bearing surfaces before assembling? I think what your going to find if you have lubricated the moving parts and it is still difficult is someone did not keep rod and rod caps in order and two or more are mismatched (Plastigauge the journals or micrometer but it needs to be looked into before forcing rotation). HTH
To clarify a few things:
I have not checked any of the clearances using plastigauge, although I will do so now. I kept track of everything so all of the parts I put together were matching, hard to know if they were originally assembled correctly. Everything went back together with assembly lube. When I say it's difficult to rotate, I'm pushing on the crank with my hands. I have not installed the crank pulley bolt, but I will try that and see how it feels. I wasn't aware of a specific sequence for tightening the main bearing caps, that I'm sure I did not follow. What is the sequence? Thanks for the responses!
1971 GT
Check this post
I had similar concerns when reassembling my block. I certainly could not have rotated the crank by hand, but it's fine.
Check this post from the thread http://www.opelgt.com/forums/125072-post42.html
#9 (permalink) | |
hmm
I'm not a weak person, I have engine in my shop ready to install I can grab the front pulley and turn it over (without plugs in it) it is not easy due to the short leverage but I know with the flywheel on it should be no problem to roll right over. Main caps are independent of each other all I do for sequence is tighten evenly to specs and tap cap and head of bolts with 2 lb hammer (tap not beat) loosen and retighten to torque specs. If anyone has better way then enlighten me as well. If you can actually rotate the crank even being hard by just using the crankshaft you probably don't even have a problem. IMO Feel free to correct
Last edited by Dennis Texas; 12-08-2008 at 05:30 PM. Reason: let out inside on rod diameter |
[quote=Dennis Texas;179631]From what you have said and your symptoms about the only thing it could be is a mismatch of the rods and rod caps /quote]
Ah, that's it. Good one, Dennis! I have piles of such rods. They're useless unless someone wants to have them resized. Not worth it. I only use aftermarket rods now, it's really really cheap insurance. You'll need to put the caps on the rods without bearings. Make sure the bores match, in other words, where the big end of the rod meets the cap, it is smooth. Look real closely, get your magnifying glass out if your eyes are as close to fifty as mine, see the hone marks? Do they meet and match top to bottom? If there's any problem seen, try switching them around until they match correctly. I bet Dennis wins "best answer" on this one.
I don't have the head or flywheel on. After reading the previous post with the attached link I think I may be making a bigger deal out of this than I need to. but I definitely will go back and check all of the clearances and the hone marks on the rods. Ugh, I bought this damn thing so I didn't have to worry about all of this. Again, thanks for the responses, I appreciate it!
