thescifiguy
Real Name: Gordon Payton
Unanswered: Reversible oil pan?
Am I going to have trouble fitting the front oriented oil pan engine in my GT? Will it hit the suspension or engine mount cross members? Are oil pans on these engines reversible? Are there pros and cons to front or rear orientation?
#2 (permalink) | |
Pans are NOT reversible as the semi-circle arcs at each end of the pan are different sizes!
#3 (permalink) | |
I would not know any CIH used in a FWD configuration. All Opel FWD cars I can think of have OHC / DOHC engines. Dieter
2.0 oil pan problem
thescifiguy
I use an auto tranny, so the fill tube is in the same vicinity as the '68 dipstick coming out of the oil pan. I'm not happy with that location and the oil pan dipstick hole seems prone to leaking, even with a new rod and felt pad. The new 2.0's location on electrical side of the engine seems much better and is higher, which would seems to leak less or not at all.
Can I use the existing parts from my 1.9 and 2.0 to reuse my '68 oil pan, but retain the use of the 2.0's dipstick hole? I haven't pulled off either oil pan yet, so, can the dipstick tube or whatever is inside the 2.0 be rotated, bent, or remounted to go towards the rear? Why don't you recommend using the 2.0's dipstick location?
I believe you will have to use all the 1.9 parts in order for it to fit. You will also have to use the oil pickup from the 1.9 and its associated support that is bolted to one of the main bearing caps.
HTH, Harold |
That dipstick position won't be going down into the sump of the pan anymore, it will be hitting the bottom in the shallow part of the pan. When it does hit bottom, it will either stop there or have to bend and contort to follow the pan, and it won't measure level well.
#9 (permalink) | |
Kalifornia Kid
Then you want to block off the opening (where the 2.0L dipstick tube came out of. Then install your 1.9L 'rear sump' oil pan, rear sump oil pick-up tube with bracket, and the continue to use the dipstick from your aluminum rear sump oil pan. You will probably also want to swap on your valve cover as well.
Detritus Maximus
OGTS has the soft metal plug to seal the unused dipstick hole in the block. Works very well.
Just make sure that you put the dipstick on the driver's side. Some pans had them on the passenger side (Kadetts, I think?). These are next to impossible to live with in a GT as you will burn your hand everytime you go to check the oil.
