Real Name: Neil
Answered: Oil Pump Gasket Leak
I took the car back to the oil place thinking they had not tighetened the oil bolt enough. The mechanic took me under the car and showed me there was no oil from the drain bolt. The oil seems to be leaking from the oil pump (gasket?) and traveling backwards onto the oil and transmission pan while I drive. I'm working on a limited budget right now. Is this something that can be managed by checking my oil level on a regular basis and adding oil when needed? Or is this something that is going to get worse quickly and needs attention asap? I would like to put a new seal on the oil pan and oil pump, but what's involved? and how expensive? |
Most Helpful Answer - Posted by hrcollinsjr
I'm not really use to pump covers leaking unless they've been damaged, usually by someone not being careful when removing the engine in a GT. Two places up front I would check for oil leaks that might look like oil pump leaks. First place would be the front seal in the timing cover and the second is fuel pumps being overtightened crushing the spacer between the fuel pump and the housing. Do check everything up above on the front of the engine as the pump is the low point where the oil is going to drip from whether it's leaking from there or not. HTH, Harold |
Uber Genius
If its the gasket on the oil pump itself then its an easy repair. The gasket is (as I recall) 100% external. What could have happened, however, is you might have a cracked oil pump cover. One way to find out is to clean it very well with carb cleaner and then start the car and look.
I will say it will get worse. Back when I was new in Opels I cracked mine. It went from a quart a week to 2 quarts a day (15 miles each way to work). It was so bad that after a couple weeks you could see the path I took to work. I thought the job was going to take a few hours to fix but I took care of it in less than a half hour. Better to fix it before it gets too bad. The gasket is a little over $2 from OpelGTsource Opel GT Source --- Online Store --- Engine Thats cheaper than a quart of oil.
Opel GT Pilot
Yeah, I wouldnt want to mess around with having a leak at the pump, it may cause low oil pressure, thus resulting in poor component lubrication. The oil pump is easy to gain access to, and easy to work on. Whatever the price, it will be cheaper than the oil to refill it, and quite a bit cheaper then replacing internals due to excessive wear. Track down the problem and repair it for good!
Good luck!
Currently in Daytona Beach, FL working towards my Bachelor's in Aeronautical Sciences (Professional Pilot). |
Real Name: Neil
So it is possible to remove the oil pump cover and put a new gasket on without opening up all sorts of other things?
I just pulled the differential cover a couple weeks ago and cleaned and painted it and put a new gasket on and changed the diff fluid. If it's as uncomplicated as that then I should be ok. And the oil pan gasket... I've been warned that's a big project since you'll need an engine hoist to support the motor when you take the motor mount off to get to the oil pan? |
#5 (permalink) | ||
Opel Obsessed
What I find strange is that this happened just after the oil change. Was anything done to the oil pump cover during this same time period? Could the oil possibly be leaking from a badly sealed oil filter gasket? JMTCW.
Randy |
Uber Genius
The oil filter ends up being close to things that could puncture it. In the interest of universal fitting some oil filters are listed that are a little longer than the engine compartment allows, especially if the motor mounts are a tiny bit squashed. Well, the oil filter ends up rubbing on the frame (or suspension, I can't remember) and will end up leaking. Check for damage to the oil filter. It's hard to see. If that is your problem, be forewarned that one bump can damage the oil filter to a point of stranding you. Mine umped 3 quarts of oil in a matter of a couple miles. Luckily I caught it before it fried my engine completely. It's worth a check.
Just a note, the oil pump cover bolts are teeny 6mm bolts (10 mm head). Tighten them nice and easy, the torque spec is something like 6-11 ft lbs!
Here's the oil pump location on the lower front of the engine (albeit this is a bit shined up!).
My Flickr photos. Jan. 3, 1984 - Jan. 3, 2009, that's 25 years of this damn Opelitis! C.R.L. 9/22/69 - 12/8/99, J.M.L. 3/3/43 - 6/15/04 Last edited by RallyBob; 12-27-2008 at 03:19 PM. Reason: adde photo link |
#11 (permalink) | |
I would be looking for a leaking oil filter (missing or incorrect sealing ring), or even a leaking front engine seal, WAY before I would suspect that the oil pump cover was leaking. It is very suspicious that the leak started immediately after the oil change, likely performed by a person or persons lacking any substantial mechanical skills at the lube shop, let alone by a person familiar with Opels.
Opel Intern
Could it be something as simple as the wrong weight oil? Or they used synthetic instead of normal oil? i know that synthetic is far less viscous than normal oil, so it finds all of the places that would normally not otherwise leak. Most likely not the case, but it never hurts to check the simple things first
#13 (permalink) | |
Sorry for the hijacking. ![]() Back to our regularly scheduled programming.
#15 (permalink) | |
No....its not a Buick....
![]() I might also be suspicious of a pinched oil filter gasket or stripped oil plug since it being so recent...... HTH Joe
What ...we got here...is........failure......................... to communicate.... Some men,you just cant reach...so you get what we had here last week...which is the way he wants it. Well, he gets it...I dont like it, any more than you men... Last edited by yellaopelgt; 12-27-2008 at 11:40 PM. |
Real Name: Neil
Thanks for all the advice and suggestions guys!
The previous owners of this car were less than attentive, but the car isn't a disaster. The first time I changed the oil was in the summer and I put 20/50 oil in the car, since the engine is older and has not been rebuilt and it got to the 90's and 100's here this summer. When I changed the oil the next time this December I'm sure the car had less than 1,000 miles on it, but I had run a couple cans of SEAFOAM through it, and the weather was MUCH cooler so I put in 10/30 oil along with some of the ZDDP from OGTS. The oil pressure usually runs about 2 or 2.5 at the highest. Lower than I would prefer. When I went back to Jiffy Lube the manager was kind enough to take me down below the car in the pit and show me the drain bolt was not leaking and he said the oil looked like it was coming from near the oil pump. I'll replace the oil pump gasket and be careful not to overtorque the bolts. My next desire would be to change the timing cover seal and see if these two things help. I didn't see oil on the filter itself so I doubt that's the problem. I'd like to do as many minor maintenance things to keep the car running as my get around town car. Obviously doing a complete rebuild would be the best solution, but not exactly in my budget at this time. What all is involved in changing the timing cover gasket? as in... what all else do I need to remove or tear down to get to it? |
#18 (permalink) | |
Uber Genius
You aren't going to like this
You see, the timing cover is put on before the head and before the oil pan. It is sandwiched between the two. On top of that, you would need to pull the water pump as there is a bolt hiding under the water pump as well. There is virtually no way to pull the timing cover without either pulling the oil pan or pulling the head. The good news is gasket sets aren't all that expensive if you buy them at Autozone. (I bought one yesterday for $83.99)
#19 (permalink) | |
Harold |
#20 (permalink) |
Oil Filter ...
If the GT did not leak/use oil before the oil change then it is surely something that was done during the oil change ...
The most likely culprit is an incorrectly fitted filter seal or a ruptured oil filter. The cheapest and easiest thing to do is get a new oil filter, remove the one that has been recently fitted and examine it carefully. 10 to 1 odds that it is the filter seal where it contacts the front cover - or the sealing face was gouged when they removed the old filter .... Make sure the correct filer has been used! Fram PH966B or equivalent. http://www.opelgt.com/forums/part-su...r-numbers.html
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 12-29-2008 at 06:29 AM. |
#21 (permalink) |
What GTJim said. That would be my bet. Quick lube
places are notorious for not making sure the old gasket came out with the old filter. You might have a double gasket situation, allowing oil to squirt out between the gaskets. Don't ask me how I know this. I'd be checking the oil filter install and whether or not it's the correct one. Where are you in Sac? Maybe I can swing by for a looksee. I'm in the Tahoe Park area. Don. |
