'72 Opel GT (Sara)
Unanswered: Oil Change Stops Engine Oil Leak
This totals 96oz (3 QTs) which is 0.25 QTs less than the 3.25 recommended for the GT model (I did this expecting the dipstick to show just a little low - you can always add more oil after the fact to get it to the full line). It's been about 10 days now since the oil change and a little over 100 miles and I have no leaks . I thought I was going to have to go through some major gasket swap someplace or worse. So, if you have a small to medium leak you may want to try this. The change in oil weight plus the Lucas stop leak seems to have done the trick. Finally, don't worry about the excessive ZDDP (the whole 4oz bottle treats 4 - 5 QTs of oil plus the Mobil 1 already has quite a bit). According to the ZDDP Plus website, using more than needed simply prolongs the life of the additive between oil changes - it will not hurt the engine.HTH Matt
