Uber Genius
Unanswered: What causes water in #2 cyl only?
I have never seen this before in all my years of Opel engines. I just removed the head from my project and here is what I found. First off I want to say "nice job" to the idiot that broke the brand new water pump that was put on the engine right before he sold it. I'm especially happy to know that the RTV sealant held long enough to get it to some sucker. But I don't really care that much about the 2 broken ears. It would have been nice though if he actually used a gasket instead of just gooping it up with RTV and praying. OK, so when I bought it it had water in the oil. No biggie. I wasn't buying the car for the engine, really. I figure I can rebuild them pretty easy. The car was going through water only when it was running. No big deal there either. I figured blown head gasket or cracked head. COOL! Piece of cake. Removed the head. Head gasket looks perfect. No aging to it at all, and having seen a number of factory gaskets I can tell this isnt a factory one. Doesn't look like a Felpro. Looks more like a VERA. Anyhow, the head gasket is intact and still pliable. I checked the #2 cyl on the head and...it looks perfect visually! It has the same amount of carbon as the other 3 BUT, the #2 piston looks steam cleaned. I mean it is CLEAN! I have seen a couple cracked heads that held water longer than this engine and the cracks were clearly visible to the naked eye. Those also had some clearly visible steam cleaning in the head in the cracked chambers. So... I will have the head checked for cracks on a more magnified level (if needed) but before I send off a possible trashed head for inspection, what else could it be besides a cracked head or blown head gasket? I suppose it could be a cracked cyl wall but i will rule that out too. Also, it should be noted that this is a low compression engine. 10 bolt head with cupped pistons. I'm thinking I should fill the pistons with JB weld before putting the engine back together to increase the compression........J/K Any ideas on why there is water in only #2 cyl? Thanks
Uber Genius
Nevermind
I feel soooooo stupid.
Decided to take a couple pictures to show (see below) to you all. Though visual inspection didn't show the crack (at first) the camera picked it up like the crack was posing for a picture. The crack is actually much worse than the picture shows. It's about 3 inches long and goes into the exhaust valve seat. So, off to the wrecking yard Saturday to pull a head and some flat pistons (cuz JB Weld is expensive ~LOL) 2 cyl.jpg engine1.JPG head1.JPG
Opel GTs are not GM products Last edited by tekenaar; 01-16-2009 at 11:26 AM. Reason: tak |
#3 (permalink) | |
1969 GT
Real Name: Tom
I have a quick question for you. Did you purchase this GT recently in Gresham/Portland OR area? Your photo looks exactly like a GT I was looking at several months ago in the Gresham area of Portland. If this is the same one the seller told me "head gasket" but I suspected at least a cracked head and maybe engine block!! Lets hope the head is the only crack.....sounds like you will be on your way to an easy repair! Best wishes. |
Uber Genius
It is one in the same.
Head cracks and blown head gaskets don't bother me at all. The first Opel GT engine I ever did was a cracked head (between 2&3 cyl). He told me it had a little "overheating problem" but I knew better. Someone had taken out the spark plugs to check the cylinders and never tightened them. I took them out by hand and the #2 was wet. You can't get wet plugs without a water leak. I'm pretty sure the block is fine (now) because the head appears to be a standard overheating crack. When I first got it I thought the block was cracked because of the water leaking from what turned out to be the broken water pump. As you know, the engine was/is so covered in sludge it was hard to see where the exterior water was coming from and it appeared to be a brand new water pump. Well it is a brand new water pump that was over torqued with a partial gasket and a buttload of RTV. Whoever replaced the water pump wasn't smart. I'm guessing it was either a kid or some guy with a mental impediment. Yeah, I know it's harsh but you should see the job this guy did.
Location: Salem, Oregon - country roads through blooming iris crops is great Opel driving here!
dough the piston
The rest of the post was out-the-window as I could only try to think of a nice way to mention how bad of an idea that would be...at so many levels!! I couldn't. I checked back later and re-read. Oh, you really got me good! LOL
Result driven. Daily blessed. |
Same thing happened here yesterday
Got a call from an Opel GT owner who said he had water in the #2
only he lives in Temecula Ca. He wanted to buy an engine I told him to pull the head first and have it magnafluxed Head gaskets and or cracks in the head are the 2 causes of water in the cylinders, do not know of any other reasons |
long time Opeler
look at the picture of #2
The picture of #2 cyl looks like a crack running up. I'm not sure I would invest in checking out this head. (if that is indeed a crack) What you need to do is buy my high comp rebuilt engine. yes, a shameless plug.
#8 (permalink) | |
1969 GT
Real Name: Tom
Well let me first say I was willing to buy that GT and I think you got a good deal for what he was asking! I decided to go with a 69 gt in S. California that was a bit cleaner and less costly on transport BUT yours was a better buy price wise! The guy you bought it from also told me he did not have the title to it but was soon going to have it. The titled owner I was told owed the seller some back wages for work done and they agreed to giving him the GT as partial "payment". As you may have gathered, the seller knew VERY little about the car as he only had it long enough to sell to get his wages out of it. I was not willing to buy the car until the title was available so in the mean time I found a 69 GT. I agree with you that the head gaskets and cracked heads are the main cause of water in oil BUT I have seen cracked blocks where the water jackets leak into the case usually due to no or little antifreeze in the cooling system in cold climates. As you pointed out it looked like a cracked block so I was thinking possible engine replacement! Glad to hear it was only a water pump install gone bad by the previous owner! In any event new motor or not I think you got a great buy and a nice GT. Good luck and best wishes. Tom |
#10 (permalink) | |
I would only add that, in CIH engines, it's more typically the #3 cylinder that exhibits this problem . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 01-16-2009 at 11:52 AM. |
#11 (permalink) | |
Uber Genius
It's a good thing I'm getting different pistons or I would be upset that the engine only cleaned one of the pistons.
