Rookie
Unanswered: Oil in Carb/Weber Airfilter pan
The hose that leads to the Weber from the Valve cover, I understand is a breather, right? There is always a lot of oil in the Air filter pan. Is this normal? Will the oil in the Weber not influence the performance. I thought that the cover had some kind of splash gaurd to prevent the oil from entering the carb? Is there something I can do to prevent this?Any help for a Rookie (I sound like my 5 year old son with all the Questions )
101st Airborne Vet V.N.
Real Name: Thomas Johnson
My answer to that would be the blowby from the valve cover is forcing oil to the pan of your filter assembly. This may also indicate the retainer (rings) on the piston may need replacement. Check your cylinder compression..
Thomas Last edited by MICAH1; 01-20-2009 at 03:27 PM. |
#3 (permalink) | |
My second thought is a simple question. Is there a vacuum line attached to the smaller hole in the valve cover? This serves as a Positive Crankcase Ventilation (PCV) valve. You are correct in the fact that there is some type of problem. Are your spark plugs oil fouled also? HTH, Harold Last edited by hrcollinsjr; 01-21-2009 at 01:19 PM. |
ditto with the above replys..sounds like blowby.
The oil rings could also be gummed up with carbon goo. I normally don't recommend a mechanic in a can but for only a few bucks it might be worth a try. Chrysler Combustion Chamber cleaner. Get the engine hot then remove the spark plugs. Fill the cylinders with the product(use the whole can) and let it sit over night. After you reinstall the plugs the next morning and start her up the whole neighborhood will be free of mosquitos. It'll be poring out blue smoke...like in massive amounts. After it clears up do some full throttle runs to help loosen up the rings. Hey its better than a rebuilt if it works. Last edited by wrench459; 01-20-2009 at 10:53 PM. |
Site Admin
Also, there should be a mesh inside the top of the valve cover to help stop the oil mist from escaping. Note: If there is none, do not use steel wool as a replacement. Use only a stainless steel mesh. |
UFO pel abductee.
Like everyone says, sounds like blowby.
If you do what people suggest and it still does it, try making/buying/installing a blow by catch tank like racers use in the breather hose.
#9 (permalink) | |
Rookie
Tested compression seems fine. It's between 8-9? The spark plugs are black but dry. I guess it's due to the Manta tuned to run a bit rich? No vacuum line attached to smaller hole. Will try that this weekend and see if it helps. Last edited by tekenaar; 01-23-2009 at 11:58 AM. |
#10 (permalink) | |
Compression is usually measured in PSI. Do you know if your engine is a high or low compression engine? An engine is going to typically show a rich condition if it hasn't been run long enough to burn the plugs clean. When you're serious about reading plugs you actually cut the engine off at speed to give a more accurate reading of what is going on. Harold |
#11 (permalink) | |
Rookie
blow by catch tank
"In a situation such as running in high speed on the race track, a car emits blow-by gas. The blow-by gas contains atomized oil, and that's exactly what this tank cleans out and is effective for preventing the blowback of the pooled oil." I might realy try this if all else fails Last edited by 74MantaRay; 01-21-2009 at 02:25 PM. Reason: pic not linked |
Site Admin
Ahh, you may be on to something.. Make sure that you connect the line to the metered port on the vacuum connection below the carb. The metered port is the one that has a very small opening to control the amount of vacuum to the valve cover. If you have access to small drill bits, you can use one to make sure that port is not blocked.
I have noticed a number of opels with the small opening on the valve covers plugged (mine included). I would think that they both sort of serve the same purpose with the larger blowing gases/fine oil,and the smaller extracting the same by vacuum assist. Would that be correct?? I have not had a problem yet.
Thomas |
#14 (permalink) | |
Harold |
#15 (permalink) | |
I've seen cars with both valve cover openings plugged, which will result in a pressurized crankcase . Don |
#16 (permalink) | |
Don, What is "the Make Up Air"??
Thomas Last edited by MICAH1; 01-21-2009 at 10:28 PM. |
#18 (permalink) | |
![]() Harold |
I'll actually be installing a pan-e-vac system on my Kadett on Friday, hopefully, to deal with my own blow-by issues. I'll take pics if anyone wants me to.
#21 (permalink) | |
Uber Genius
I thought pan-e-vac systems were only recommended for racing vehicles. I had heard, somewhere, that they weren't recommended for daily drivers. Am I wrong?
#23 (permalink) |
Mostly it just gets the oil mist in the tail pipe instead of the carb, and while it's not so environmentally friendly it shouldn't hurt anything the way I'm doing it.
#25 (permalink) | |
And do you really want to pull those oily vapors into the nice clean throat of that Weber? They don't exactly just "go out the exhaust" - they're pulled into the manifold to the combustion chambers and burnt, same as when they're pulled into the manifold by the small vacuum hose. Opel designed the engine with a positive crankcase ventilation system operating as described earlier. Why would you not want to run the system as it was designed? Don |
