Old 03-16-2009   #1 (permalink)
tomking's Avatar
Unanswered: Cast or Forged Rods?
I am trying to identify which are cast and which are forged. I know the hump at the squirter means forged but are some of the other rods also forged but without humps? I believe, well I hope that only the last picture is a cast rod on left side of the picture. What do you think?
TMK
tomking is offline
Old 03-16-2009   #2 (permalink)
opeldean's Avatar
cast verses forged
I think you are correct, the cast is on the left of your last photo. It is thicker looking and more rounded.
Enclosed is a picture from my rebuild that RB identified for me, in my rebuild thread.
when compared, the forged look thinner ,sharper angles and less beefy.
File Type: jpg forged verses cast_09 Mar. 16 20.14.jpg (77.6 KB, 50 views)
opeldean is offline
Old 03-16-2009   #3 (permalink)
Correct, last pic...left side rod is cast (brand new judging by the coating!). The rest are forged.
Old 03-17-2009   #4 (permalink)
tomking's Avatar
Thanks for your help guys. Yes the cast one is new. I had been searching for the comparison photos but hadnt found them.
TMK
tomking is offline
Old 06-20-2009   #5 (permalink)
neuropel's Avatar
Well, I thought I had this issue straight, but now I'm second-guessing myself. Pictured in the first photo below (on the left) is one of a set of newly reconditioned forged rods. The rod beside it (still with piston) was pulled from the block I'm having bored for a 2.2. It looks to be forged as well, but appears to be a bit more beefy (plus, it has a funny hump near the oil hole). Can someone confirm that both of these are forged rods? Pictured in the second photo is a rod/piston assembly I pulled from my '74 Manta, which was supposedly a stock engine. Is this also forged? If so, is it typical for a '74? I thought most Opel engines had cast rods. The reason I'm second guessing myself is that every Opel engine I pull from my parts stash seems to have forged rods, and I'm wondering if this is really the case.
Are the rods in the first photo of equal strength?
Todd
-Abraham Lincoln
________________
1972 GT 2.4L
1974 Manta GT/E 2.2L
1973 Manta Rallye 2.5L
neuropel is offline
Old 06-20-2009   #6 (permalink)
neuropel's Avatar
Well, after looking through this thread and others, it sure looks to me like the clean rod in the first photo is actually a cast rod, not forged - also the rod in the second photo looks cast.
-Abraham Lincoln
________________
1972 GT 2.4L
neuropel is offline
Old 06-20-2009   #7 (permalink)
Todd
Todd, the left-hand photo shows a cast rod on the left, forged rod on the right. The right-hand photo shows a cast rod as well.
HTH,
Old 06-20-2009   #8 (permalink)
neuropel's Avatar
Thanks for confirmation Bob. I think what was confusing me was that the rods were sold to me as forged rods, when in fact they are cast.
-Abraham Lincoln
________________
1972 GT 2.4L
neuropel is offline
Old 06-20-2009   #9 (permalink)
I agree with Bob, the "reconditioned" rod on the left is cast, as is the rod in the photo of the one rod/piston. AFAIK, only 1974 and 1975 (maybe late 1973) engines had cast rods, all the earlier ones were forged. It is fairly easy to tell them apart, as the cast rods have a thicker web at the base where the beam connects to the big end.
The forged rods are stronger, but I don't believe that the cast rods are actually "weak". That is, I would use a forged rod for an engine that I was building up, but by the same token, I wouldn't hesitate to use a cast rod for a street engine, unless I had a set of forged rods that were in equal condition.
JM2CW
Old 06-20-2009   #10 (permalink)
guyopel's Avatar
The cast rods were the only replacement from the Dealers
and all 4 rods had to be replaced even if you need only one. The '75 FI engs. all had cast rods from the factory .
John
Guyopel
---Thomas Edison
guyopel is offline
