Unanswered: 4 Bearing cam in 3 bearing head
1971 GT
I am running a 4-bearing Isky OR-66 cam (.430 lift) in a 3-bearing head right now. I have no issues but I have dished pistons. You may run into problems with flat-top pistons.
Yes, I am thinking of putting this cam in my 1970 with the original flat top pistons. I spent some time searching and from what I have seen, it looks like it should be fine for piston clearance. I did not know if the cam might suffer from some sort of flex with only the 3 bearing support and incresed lift. Sounds like you are running it with no problems.
1971 GT
Same cam but I ordered it direct from ISKY online. It was far cheaper.
I only have a few hundred miles on my set-up but I don't think there should be any flex issues.
1971 GT
I had the benefit of time with my build. I bought my lifters from a source on E-Bay UK - also at a greatly reduced price.
Isky Cam in three bearing head
You will not have any issues running that cam in that head even with flat top pistons there are no clearance problems. You will need to put a .030 shim under the valve springs to get the proper spring pressures for that cam. If you are running the rotator under on the exhaust valves, the shim goes under the rotator not the spring. Hope that answers your question
Last edited by tekenaar; 04-16-2009 at 11:17 AM. Reason: is no clearence problems |
Valve Lift
In answer to your question, No, not with stock rocker arms. Cam Manufactures advertise cam lift based on lift with a 1.5 rocker ratio and stock Opel CIH rockers are a 1:44 ratio. If you really want true lift you have to measure lobe lift, at the lifter with a dial indicator and multiply by 1:44 and that will put you in the ballpark, if the rockers you are using are all truly 1:44 and not all of them are.
#16 (permalink) | |
FWIW
#17 (permalink) | |
Rocker Ratios
