thescifiguy
Real Name: Gordon Payton
Unanswered: E-block?
What are these E-blocks/heads that he's likely to be talking about? Are we just talking about standard 2.0/2.2 engines or special versions of them? Did 1.9 engines come in some "E" variation?
#2 (permalink) | |
My Flickr photos. Jan. 3, 1984 - Jan. 3, 2009, that's 25 years of this damn Opelitis! C.R.L. 9/22/69 - 12/8/99, J.M.L. 3/3/43 - 6/15/04 Last edited by tekenaar; 07-15-2009 at 12:49 PM. Reason: nornal? desireable |
#3 (permalink) | |
open up number one intake track. Don't ask why. Is it possible/or wise the reconfigure the coolant flow on the 1.9(1971ish) to a later model? Sorry off topic again. It looks like a no brainer but I thought I would ask first. Last edited by wrench459; 07-14-2009 at 11:38 PM. |
Enspritz - Injection
That is what the 'E' stands for - I guess 'S' stands for Suckspritz - carburettor! (I am sure Otto can correct that ..)
The water for fuel injection motors is routed through the by-pass hoses rather than through the block hole to get a better temperature reading as the injection motor warms up with the thermostat closed. So with injection you really need to modify away from the block hole (just block it off) to the different recirculation path used for injection motors. IMHO
Second, engine temperature control can be accomplished in its most simple form by blocking off the coolant flow through the radiator almost entirely by using a "single-stage" T-stat, which opens when a set temperature is reached. Once the engine is up to its "operating" temp, the T-stat then regulates this temp by alternately opening and closing off the coolant flow through the radiator. Coolant system flow in this setup is never entirely stopped as that would cause water pump cavitation (coolant aeration) during the warm-up phase. This is the whole reason for the "coolant bypass passage" from the T-stat at the head, through the timing cover back to the water pump intake (head-gasket rubber O-ring at the timing cover, remember!). This is the universally used system for carbureted engines until FI came along. FI systems use engine temperature as one of the many inputs to control precise injector fuel mixtures at all engine speeds and loads. Engine coolant temperatures must be much more precisely controlled for this reason, which resulted in the adoption of the "dual-stage" T-stat and altered coolant routing. In our CIH engines, the change from "carb, single-stage" to "FI, dual-stage" T-stats was accomplished by blocking off the "carb" coolant bypass passage at the head and the addition of a new, T-stat controlled bypass hose routed from the '75 FI T-stat housing directly to the water pump intake, the 90° center hose. The lower radiator hose is now routed directly to the FI T-stat housing rather than to the water pump intake. I can personally attest to how well this tri-hose, dual-stage T-stat "FI" system works with a carbureted engine, my dual carbed Kadett 1.9 sprint engine!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-16-2009 at 11:24 AM. |
