Unanswered: valve to piston clearance
If you dial in the cam at 106 and advance the cam two degrees wont you be at 104?
No there's no way the racers will push the limits to the extreme.. ![]() BTW I like .100 on the intake and .080 on the exhaust just personal preference as a rule of thumb for a street motor. |
#3 (permalink) | |||
Thick Head Gasket ...
A thicker head gasket just reduces the 'squish' or 'quench' between the head and pistol top flats and encourages detonation. Not good!
Looks to me like your only real option is to dig the valve notches deeper into the piston tops - taking care to check that there is enough thickness there to allow this. Should be about .250" of metal (aluminium) left under the thinnest point (where the valve notch is deepest). HTH
Sorry for my dyslexia on the intake and exhaust numbers and I DID retard the cam 2 degrees. Yes it is a roller cam which was not ground to the specs I needed. I also talked to Cam Techniques, and he said the cam could be reground but he was not to keen on it because he did not know how deep the heat treet is. I guess my options are to deepen the valve reliefs or ditch the cam for a solid lifter or spend big $$ for the thick gasket that is going to lower the comp ratio. thanks for all your help, chris
I watched someone who was in a pinch use a Dremel with an Aluminum cutter and a very steady hand deepen the valve notches before. Then he checked them on digital scale and they were still amazingly close to each other weight wise.... Just a thought.
Paul |
A few options that you have:
*Thicker head gasket (but costs a bunch of $$$, especially if you ever need to replace it again, plus waiting time) *Pull off the head, recess the valves in the seats a bit (costs money, reduces compression, reduces low-lift airflow) *Pull engine apart, send out pistons to have valve notches deepened (cost money and time) *Have camshaft reground (costs money, questionable heat-treat?) *Buy Isky valve notching tool and do it yourself (costs money to buy tool, you must know exactly where to use it [crank location relative to valve timing]) So no matter how you look at it, it'll cost you something. However it's certainly not insurmountable. Bob
