Old 09-08-2009   #1 (permalink)
kiekmer's Avatar
kiekmer is on a distinguished road
Answered: Engine problem, much coolant in oil
Hello,
I have a problem with the engine of my opel gt. This weekend I checked the oil level, and to my surprise the oil level was way to high (50% above max)!!!!
The thing was that about 2 liters (1/2 gallon) of coolant was heaped on the bottom of the sump. The oil was also mixed with the coolant (Sludge). The engine was recently fully revisited with new camshaft, cilinderhead, pistons, gaskets etc.
After disassabeling the engine head I made some pictures. Does anyone have an idea what could have gone wrong?
Gr. Roel
Opel GT 1969 * 2.0E CIH * 5-gear * Sprint manifold * 15" BBS
kiekmer is offline
Most Helpful Answer - Posted by yellaopelgt
I have always re-torqued the head after a few miles as well. Since you stated that the motor was re-built, that may have been part of the problem. just thought I'd mention it.
Joe
Old 09-08-2009   #2 (permalink)
Nathan Acree
There is a small rubber seal that goes in the large hole closest to the timing case. If you leave that out you can get a severe coolant leak.
Nathan Acree is offline
Old 09-08-2009   #3 (permalink)
I see red silicone around the hole where the small rubber seal Nathan is talking about is supposed to go. When installing a new head gasket you may want to check out the modification (info on this site) whereas two holes are cut in the gasket to allow for more even cooling of the #2 & #3 cylinders.
Old 09-08-2009   #4 (permalink)
kiekmer's Avatar
Thanks for the quick reply guys! The small rubber seal was in place, we just made sure it didn`t leak by putting a small amount of silicone around it.
Grtz Roel
kiekmer is offline
Old 09-08-2009   #5 (permalink)
opelwasp's Avatar
Grtz Roel
Was this seal reused? You must NEVER reuse this seal. It seals by compression. If it is reused it will never reseal. It is made to squish into place and be replaced when the head is removed.
opelwasp is offline
Old 09-09-2009   #6 (permalink)
kiekmer's Avatar
The seal was also renewed. I have a suspision that the head may not be bolted firm enough. Could that be?
kiekmer is offline
Old 09-09-2009   #7 (permalink)
Wolf Spyder's Avatar
Wolf Spyder is on a distinguished road
If you did not tork the head to the right amount in the right order you could have the leak that caused your failure. Have the head checked for warpage before you re-build.
LIFE IS NOT A JOURNEY TO The GRAVE WITH THE INTENTION OF ARRIVING SAFELY IN A PRETTY AND WELL-PRESERVED BODY, BUT RATHER TO SKID IN BROADSIDE, THOROUGHLY USED UP, TOTALLY WORN OUT, AND LOUDLY PROCLAIMING...
"WOW! WHAT A RIDE!"
Wolf Spyder is offline
Old 09-09-2009   #8 (permalink)
GT Racing
SantaClaw's Avatar
Real Name: Andreas. H
SantaClaw is on a distinguished road
My oil level also increased due to coolent..
But the culprit was a little easier to find...
-1992 Opel Vectra Expression 2.0i-8v turbo, C20NET
-1973 Opel GT Racing 2.0i-8v 20NE +++
-2009 Polaris 600RR (Snowmobile)
-1972 Bombardier Elan 250 (Snowmobile)
My location
SantaClaw is offline
Old 09-10-2009   #9 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
Joe
yellaopelgt is offline
