Then
While the valve cover is off, have someone turn the engine over, and see how far the rockers are moving, IE: are the valves are opening for #2. You might have a rounded off cam lobe or two.
No, it's only a four cylinder! |
Real Name: Tom
A quick check method (although not a 100% accurate), shoot a little oil in the bad cylinder and recheck the compression. The oil will provide a temporary seal around the rings, so if the number goes up you most likely have a ring issue. If it remains the same it would probably be valves. I have had good success using this method to get a staring point.
Tom |
Update on low compresson readings
Thanks everyone for the suggestions.
I thought I would post an update. Cam/rocker/valve system seemed to be working OK, so I pulled the head today. Looking at the top of the pistons, the #2 piston has a piece missing from the top at the edge of the piston. It is about 1/4 inch by 30 mils, and you can see the cylinder wall is scuffed a bit in this area. The top of the piston looks as though something bounced around on the top a few times, but nothing was laying loose on the piston when I removed the head. I am thinking that I might have broken a ring, but I won't know for sure until I pull the engine and remove the pistons. The #4 piston looks OK from the top, so I am still not sure why it was showing very low compression. Maybe something else happened there. I will post again when I have the pistons out. Thanks Grady |
1971 GT
Corey
