Hello. It's been a while since my last posting and I'm back with a problem: during the last run of the season my engine began missfiring and losing power. Found nearly 0 pressure in no 4 cilynder due to a cracked CF21 solid lifter from Kent Cams - in february 2009 I went for their OP264 camshaft together with followers and ran them ~500 km for breaking in and ~100 km in racing conditions (only 2 events due to low budget issues).
I sent to Kent Cams some pics and this story getting this answer:
"Dear Sir,
Thank you for your recent E-mail ,looking at your photos it difficult to be 100% accurate in the reason for failure, however it looks like the follower has suffered some heavy side loading, the reason I say this is because this product it very strong in a compression state, which is it's natural working environment.
If you would like further investigation, please return the part to either the company you bought from, our directly to our company
Best regards,
Del Johnson,
Kent Performance Camshafts Ltd."
Wenting further but with my own investigation I found another follower with a loose tap. I strongly believe that it's a manufacture problem, the margin suporting the tap beeing uneven (0,3 mm on one side vs 0,7 on the opposite one) on the cracked one, leading to tilt the cap. What do you think?
I had to cut the broken follower to get the tap out of it.
