Question: Motor mount shim
Results 1 to 11 of 11
Like Tree6Likes
  • 1 Post By RallyBob
  • 1 Post By Dmcbrass
  • 2 Post By opelspyder
  • 2 Post By P.J. Romano
Thread: Motor mount shim
    Dec 2014
    Green Bay Wi
    41
    Motor mount shim
    Couldn't find any info on this in any of the forms. under my motor mount on the driver side was a 1/8 inch thick shim. Has anyone ever seen this before ? I understand the engine is tilted to give clearance for the air filter box and this is accomplished with the motor mount brackets.
    Can Opeler Knorm65's Avatar
    May 2014
    Wichita Falls and Munday, Texas.
    1,739
    Kyler Norman
    4
    You should have that shim on both sides (at least that's how it's been on both of my GTs). I think they were between the crossmember and body though...
    Spofford, NH
    12,475
    Bob Legere
    The crossmember shims are some sort of phenolic/plastic material. They have two holes per shim, so the metal shim in the pic is definitely not the same piece.
    Looks like someone may have used an alignment shim to help prop up a sagging engine mount.
    1stcarGT likes this.
    Member My location Dmcbrass's Avatar
    Jan 2004
    North Creek, NY
    834
    Doug
    4
    I did this on my car to create space between the new exhaust header and chassis.
  7. #5
    Dec 2014
    Green Bay Wi
    41
    Does anyone have info / Pic's on the cross member shims that are some sort of phenolic/plastic materiel with 2 holes. I didn't have anything like that when I took it apart.
    Thanks so much for all the help
  8. #6
    Tennessee
    4,152
    Keith Lundholm
    Guys, this is a factory shim for between the engine frame and the body frame. If you run a factory sway bar, these are removed and the mounts for the sway bar are used instead. There will be two, one on each side on the inner most bolt area
    Now I've seen them mounted other places because people didn't know where they came from.
    jmbinjax and P.J. Romano like this.
    www.newvintageauto.com
  9. #7
    Tennessee
    4,152
    Keith Lundholm
    Crossmember to body frame phenolic spacers go here on both sides, each have two holes for the bolts that secure the crossmember
  10. #8
    Dec 2014
    Green Bay Wi
    41
    Thanks for the help.
    I do not have the shim for the sides or the phenolic shims
    Their is a guy close to me that has stripped a lot of cars down for parts.
    Hopefully he has the shims for both the side and bottom.
    if not Could you give me the thickness of both so I can make something ?
    Again thank you for taking the time to help
  11. #9
    Tennessee
    4,152
    Keith Lundholm
    GT Source has the phoenolic spacers new, the other metal shims you had one in your hand, you just need to find another
  12. #10
    Aug 2006
    Goderich, Ontario Canada
    2,707
    P.J.
    Quote Originally Posted by 1stcarGT View Post
    I hope you realize, this is about two different cross members.
    Engine cross member requires one shim on both sides, you are showing it in your picture. Those shims should be installed as per Keith's instruction few posts ago.
    Front suspension cross member requires phenolic inserts and they are available from OGTS Fiber Spacer - Original Front - Suspension - Opel GT - Store | Opel GT Source
    norbertone.gt371 and 1stcarGT like this.
  13. #11
    Dec 2014
    Green Bay Wi
    41
    Yes this makes sense. Not pulling the suspension this year and I checked and the fiber spacer is their on both sides. Ill duplicate the spacer to go between the eng cross member. Hopefull the cars coming back painted soon so I can start putting it together.
    1. Motor Mount Orientation
      By The Scifi Guy in forum 6A - Engine Mechanical
      Last Post: 03-09-2014, 04:46 PM
    2. 1.1L motor mount tips
      By 73Manta72gt in forum 6A - Engine Mechanical
      Last Post: 06-18-2007, 11:09 AM
    3. Motor Mount Brackets
      By Gary in forum Ascona (1900)
      Last Post: 06-13-2006, 08:45 PM
    4. Help With Motor Mount Brackets
      By birds_of_fire in forum Mechanical
      Last Post: 04-15-2005, 10:08 PM
    5. driverside motor mount
      By pvcar in forum 6A - Engine Mechanical
      Last Post: 01-09-2005, 10:31 PM
