Unanswered: Seized engine block drain plug. Danger removing it?
Summer approaches, and during first days of June I ought to flush/refill the cooling system. The problem is that the drain plug is SO seized in place, even after a week of daily spraying WD40 on it it still refuses to work loose... I am close to giving up, but my question is, if I somehow manage to remove it, is it possible that threads and local area inside could be rusted/corroded to the extend that it would not seal again? The system must be pretty clean because after 2 years the fluid still looks "relatively" clean... The flushing is not much of a problem. I will bypass the heater core, remove thermostat (will be done anyway, I always replace it every 2 years just in case), and fill/empty twice with clean water, running the engine between to circulate the water... Replace thermostat afterwards and fill with coolant solution...
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by tekenaar; 07-31-2008 at 01:15 PM. Reason: realatively; flusing; thermosta |
tomking: good idea, I will try to borrow one if I locate.
Main question though is: could the corrosion be such that removing the plug will make it impossible to seal afterwards, and thus I should avoid it? Has anybody experienced such a condition?
long time Opeler
75 MANTA A "2.0 Euro stuff! Fun and Fast "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." Last edited by tekenaar; 07-31-2008 at 01:16 PM. Reason: penatrant |
PB products might not have made it to greece they have only just got to the uk
i like heat and a hammer but im a blacksmith
Cam-in-head?
-Kurt |
Ron 72 GT 3.4L V-6/T-5/ZF posi - almost done - Just need AC installed. ![]() 75 Chevy monza 5.7L/TH350/Auburn 3.08 posi - Next Last edited by tekenaar; 07-31-2008 at 01:11 PM. Reason: bot heater hoses? ;-b |
Thanks everybody for your responses!!!!
I failed to mention that I do flush the heater core at the same time, but seperately. So there goes one... I will try the suggestions for the stuck drain plug... The biggest problem is the location, that makes certain tools (like extensions and such) useless, and applying effort difficult...
Phew, I just finished
the cooling system! I did it early, cause early came the summer heat. It was 35*C today, and during city driving after highway the engine was not happy at all, temp went a tad over the middle when I idled it for 5 mins, but during driving everything was fine... So when I came home I immediately opened the rad cap (no I did not get burned, I was carefull ;-) ) and a nice brown rusty crust was floating... ooops!!! Propably checking the rad when cold was letting this filth settle and made coolant look crystal clear... So the tools and buckets came out. I finally did it the very-old-fashioned way... [Warmed engine to circulate water, emptied from bottom radiator hose, flushed radiator, replaced hose, refilled]x4. I also had the cap off during the procedure to observate what filth came out of the enngine during circulation. The first two times an oh-my-god solution came out. Clean water within 15 minutes was turned to brown "filthy brake fluid" looking condition. Third time only a bit of foam, and finally the fourth clean sparkling water came out. Four flushes took about 1+1/2 hours, cause I let it get hot and circulate a lot each time... In went a nice new coolant solution, and that's all about it for another two years (at least I hope so!!! )So I didn't need to remove the drain plug after all!!!! Thank you all for every single reply!
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by gr_diver; 05-24-2006 at 04:42 PM. |
I can't find that damn drain plug! the manual tells me it exists, and yet I cannot seem to see it. The A/C covers the whole right side of the engine, and I've tried the oil sending unit to see if that could be it (ya, I know). Still, where the hell is this mystic plug?
1972 Opel 1900GT -performance cam - High compression cylinders -K&N box intake - Performance headers -Electronic ignition - Weber 32/26 -A/C (currently not functioning) - XL radiator -Beer can overflow -and of course, a Cherrybomb exhaust... and a Blue 2004 Suzuki SV650S for kicks... |
From the oil sender go up two inches and aft an inch and a half.
'72 Opel GT (Sara)
Self inflicted wound...
So I over tightened my fan belt and destroyed my water pump (new one arrives tomorrow - this will be Sunday's little project). Do I have to mess with this drain plug when flushing the cooling system? I don't recall reading in the FSM that you have to remove it. Also, is the 1/2" down / 1/2" up flex test the best method to make sure your fan belt is adjusted properly? I had a squeal and got carried away on tightening it up
...Thanks, Matt
Matt, when the pump comes off, you're going to lose a LOT of antifreeze, in that you have to drain the radiator.
#14 (permalink) | |
'72 Opel GT (Sara)
Thanks, Matt
Matt, the squeal from the belt was probably caused by and old belt that was glazed on the contact surfaces. If it was a fairly new belt, then probably the pump was giving up the ghost. The 1/2" deflection is probably the best way to adjust the belts, although there is a device that measures belt tension, but is rather expensive for the average mech and isn't used that much anyway. HTH.
Ron 72 GT 3.4L V-6/T-5/ZF posi - almost done - Just need AC installed. ![]() 75 Chevy monza 5.7L/TH350/Auburn 3.08 posi - Next Last edited by namba209; 07-31-2008 at 02:24 PM. |
I always see if I can move the logest part of the belt up & down 1 cm both ways
#17 (permalink) | |
You don't need to remove this drain, but, in the need to flush out your system, there is a better way. Prestone has a "back flush" system that has an attachment to one of your heater hoses and you can hook your garden hose to this, open the heater valve on your heater core and back flush all the old coolant out of the heater core, head/block and radiator in one shot. This system will also allow you to remove all the air out of your cooling system, much like bleeding your brakes, to make your cooling system more efficient.
