Old 10-22-2006   #1 (permalink)
Location: georgia halfway betwixt Chattanooga and Atlanta
ging
Unanswered: 160 or 190 thermostat
Need some advice folks. '70 gt not getting warm (heater). Good flow thru the heater core. Temp gauge only goes up to about 140* (even at highway speeds). Likley a stuck open thermostat. Local auto supply company does not carry GT thermostats. OGTS carries 2 flavors of thermostats 160* and 180*. Which one is recommended? The car is a daily driver and is done so year round. Winter is coming and we have VERY little heat. We live in the south. Beleive it or not... it does get cold here. Which would you folks recommend.... 160* or 180* ?
Thanks a bunch
Ging and Dan
Ging
"You may have had an Opel, but I've got one!"
ging is offline
Old 10-22-2006   #2 (permalink)
baronbors's Avatar
baronbors
Originally Posted by ging View Post
Need some advice folks. '70 gt not getting warm (heater). Good flow thru the heater core. Temp gauge only goes up to about 140* (even at highway speeds). Likley a stuck open thermostat. Local auto supply company does not carry GT thermostats. OGTS carries 2 flavors of thermostats 160* and 190*. Which one is recommended? The car is a daily driver and is done so year round. Winter is coming and we have VERY little heat. We live in the south. Beleive it or not... it does get cold here. Which would you folks recommend.... 160* or 180* ?
Thanks a bunch
Ging and Dan
Evan in Georgia heat, it can't compare to Houston but you probably are cooler than we are- I run the 180 with no problems
baronbors is offline
Old 10-22-2006   #3 (permalink)
timemachine's Avatar
Real Name: Jim
Provided Answers: 7
Stock thermostat is 189 F (87C), which also brings the engine to the proper running temperature. If you are chilly, why not go with that?
Also, make sure your heater bypass valve is working properly and that the water lines as well as the heater core are clear. A flush wouldn't hurt.
Jim
'74 Manta ("Sig")
'75 Sportwagon (project)
'72 GT (whenever I get to it)
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
timemachine is offline
Old 10-22-2006   #4 (permalink)
Originally Posted by timemachine View Post
Stock thermostat is 189 F (87C), which also brings the engine to the proper running temperature. If you are chilly, why not go with that? Also, make sure your heater bypass valve is working properly and that the water lines as well as the heater core are clear. A flush wouldn't hurt.
Jim
Pretty much all on the site know my thoughts on thermostats, but I'll say it one more time. A high rating thermostat allows the coolant to stay in the radiator longer to get cooled down by restricting the coolant flow into the engine. What I've done in the past, is to remove the heater coolant valve and thoroughly clean it. Also I have a high pressure fitting I put on a regular garden hose and force the fitting into the heater hoses which assists in flushing the heater core. I just swap the fitting from hose to hose which effectively reverse flushes the core until I get clean clear water out of the hoses. HTH.
Old 10-22-2006   #5 (permalink)
Opel CIH thermostats (except the '75 EFI) are the same as for a Chevy small block. Buy them at ANY auto-parts store.
Old 10-22-2006   #6 (permalink)
73Manta72gt's Avatar
73Manta72gt
some folks run 190s in the winter and 160s in the summer..gives a little more heat in the winter and keeps the needle out of the red during city driving in the summer.
73Manta72gt is offline
Old 10-22-2006   #7 (permalink)
guyopel's Avatar
Yes, the thermostat for a 70 to 80 model Chevy. V8 will fit . I use the 180 deg. NAPA and Pep-Boys and others should have one in stock.HTH John
Guyopel
---Thomas Edison
guyopel is offline
Old 01-27-2007   #8 (permalink)
Supercharged 2.4
Gumby's Avatar
Is there a specific item number (or engine) so I can make sure I don't get the wrong one? Or can I just go in and say I need a thermostat for a 70 - 80's chevy small block V-8?
Gumby is offline
Old 01-27-2007   #9 (permalink)
baronbors's Avatar
baronbors
I just went into Auto Zone today and asked for a 71 opel GT thermostat- it is in their data base. Thermo and gasket=$8
Old 01-28-2007   #10 (permalink)
Jim
DITTO! The lower temp thermostat will increase engine wear over the OEM spec one.
