Old 11-16-2006   #1 (permalink)
Snakes111's Avatar
Snakes111 is on a distinguished road
Question Unanswered: Fan is not working!!!
One morning when i went out the fan on my opel quit working it trys to turn but just make a squeling noise any sugestions?
Snakes111 is offline
Old 11-16-2006   #2 (permalink)
opelwasp's Avatar
I'll bet your fan belt is loose or needs replacing.
opelwasp is offline
Old 11-16-2006   #3 (permalink)
timemachine's Avatar
Real Name: Jim
Provided Answers: 7
Or more likely your water pump bearing is shot. See if the pump turns freely, then check the alternator the same way. Loosen the belt to check if it isn't obvious.
'74 Manta ("Sig")
'75 Sportwagon (project)
'72 GT (whenever I get to it)
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
timemachine is offline
Old 11-16-2006   #4 (permalink)
Real Name: Matt
matl59
Are we talking the water pump fan or the heater fan? I read your post and thought heater...
In either case squealing would probably be bearings.
If its the heater then you will have to remove it and lube them. Kind of a pain.
If its the water pump check the fan belt tightness. If its not the fan belt then replace the pump. Or as Timemachine suggests, check the alternator.
Good Luck!
matl59 is offline
Old 11-16-2006   #5 (permalink)
Alberta Opeler
Ray Morley's Avatar
Ray Morley is on a distinguished road
I remember back in 1977 on one cold wimter morning I went into the garage to start my Kadett to go to school.
What probably happened was...........the night before when I drove in to the garage a cat followed me in to escape the cold and crawled into the engine compartment from the bottom to keep warm near the rad.
When I started the car in the morning I heard this squeling sound and a large bang.
My 5 bladed fan was now a 2 bladed fan and I saw this cat.........I do not think I killed it as it took off out of the garage.
Now this probably does not solve your problem at hand but I thought it would be one item to cross off of your list.
Ray Morley is offline
Old 11-16-2006   #6 (permalink)
OPEL PARTS GREECE
alpharm's Avatar
alpharm is on a distinguished road
From the first look it seems like fan belt.
But you have to check the water pump if it working or stacked.
If the bearing would be damaged then there would be a water leak from the bottom of the pump shaft
alpharm is offline
Old 11-16-2006   #7 (permalink)
jvandyke's Avatar
Sorry to go OT but my cat once climbed inside the fender (between the panels) of my 66 Cutlass. He spent the whole day in there, 20 some miles to and from work and all day in the sun on a very hot day. He lived.
jvandyke is offline
