Old 05-21-2007   #1 (permalink)
Jasper's Avatar
Jasper is on a distinguished road
Unanswered: 3/4 mark Temp
Just put the head back on the Manta. Seems to run okay. However, the temp is on the high side. Before I took it apart, it was running at the 1/3 mark with a 180 deg thermostat with a few bypass holes drilled around the edges. When I put it back together and experienced the higher temps. I again changed the thermostat (180 Failsafe), with no result. The radiator was just at the shop, cleaned and given a good bill of health. The coolant in the radiator never looks agitated and the upper hose never feels full. I haven't run it without a thermostat, but I guess I ought to try that just to see. Are Opels picky about thermostats?
Is it possible or a common problem for the for the water pump impeller to fail or spin on the shaft?
Any other ideas. Just don't want to overheat it yet...or ever.
Thanx
Justin
Keep On Rockin The Freebird
Justin
74 Manta
79 Porsche 911SC
98 Mazda Protege
Jasper is offline
Old 05-21-2007   #2 (permalink)
Did you check the new thermostat to see if it is opening at the correct temp? I've seen new ones fail or never open. It's a simple thing to check, a pan of water on the stove with a cooking thermometer, to see at what temp the thermostat starts opening.
Old 05-21-2007   #3 (permalink)
soybean's Avatar
Mine was overheating today too on the way back from V.I.R. I have a 180 degree in it and a 160 on the shelf that I'm going to replace it with for the summer. As Ron said check it with a pan of water on the stove with a cooking thermometer, to see at what temp the thermostat starts opening.
Hth, Jarrell
soybean is offline
Old 05-21-2007   #4 (permalink)
bq97
Jarrell,
Unless your 180 degree thermostat is not opening properly replacing it with a 160 degree thermostat will not solve the overheating problem.
Once the thermostat opens the overall efficiency of the system determines the operating temperature. The 160 degree thermostat will open sooner and the temp will climb to the temperature the system can handle. If the system can’t dissipate the heat faster than it’s generated, the system overheats.
BQ
bq97 is offline
Old 05-21-2007   #5 (permalink)
Jasper's Avatar
Now that you mention it, the thermostat was open when I opened the housing and I grabbed it out and watched it close. Yes, it was hot and I made a mess.
Justin
74 Manta
79 Porsche 911SC
98 Mazda Protege
Jasper is offline
Old 05-21-2007   #6 (permalink)
this is a good way to warp things , never strip the cooling system or take the cap off when its hot as all the heat stays in the metal instead of passing through the water and cooling naturally , even when it over heats let it cool on its own first
your safety tip for today was brought to you by baz
Old 05-21-2007   #7 (permalink)
jvandyke's Avatar
I have the opposite "problem". My temp gauge has never made it to the half mark, mostly stays put at a bit past 1/4. It does move so I guess it's working. Just don't want a false sense of security if it's reading wrong. I do have a 7 blade fan, no shroud. There is auxiliary fan in front of the radiator but it has never come on on it's own and I suspect it doesn't work. I should test it I guess. No idea what thermostat is in there either. Should I investigate something or enjoy the cool running?
Last edited by jvandyke; 05-21-2007 at 09:25 PM. Reason: had fix spelling before "someone else" did ;-)
jvandyke is offline
Old 05-22-2007   #8 (permalink)
Jasper's Avatar
Jvan, if it ain't broke, don't fix it. Enjoy the cool running!
Noticed yesterday, I had to drive it to the store and the gauge stays around the 3/4 when driving, but sitting at a long light it moves down to about 1/2. Perhaps I'll get a 160 stat.
Yeah, yeah, I know about all of that warping and junk. Was kinda having to hustle it though.
Justin
74 Manta
79 Porsche 911SC
98 Mazda Protege
Jasper is offline
