4ZUA787
Unanswered: water pump
SPC Juneau |
#2 (permalink) | |
GTer
Real Name: Patrick
According to the OpelGT Owners workshop manual the tension of the fan belt is correct when the belt can be manually flexed by approx. 1/2 inch midway between the generator pulley and the fan pulley. Succes fixing the car, changing the waterpump isn't that difficult. Best regards Patrick
Definitely EX-member of the MWTE! © Mr. Corey Suggs |
#3 (permalink) | |
UngerDog
Jerry |
I can tell when my belt is loose. It squeals when the rpms get up there. 1/2" deflection, 1/4" up another 1/4" down or so I've read. I haven't heard the twist 90 method.
'72 Opel GT (Sara)
Matt
Water Pump
From Item #8 of the "GT Things to Know" article
"Carry a selection of critical Opel parts in the car: Fan Belt, Water Pump, Fuel Pump, Ignition Points & Condensor, Lower Radiator Hose, Hose Clamps, and Gaskets. (Good place is in rim of a spare). Tools to carry include metric 8, 10, 11, 13, 15, 17 & 19mm wrenches, with "special" 8, 10 & 12mm serrated bits, feeler gauges, 13mm stubby wrench and 11, 13 & 15mm obstruction wrenches. Supplies to carry: Tire & gasket sealers, starter spray and flashlight." This information, when followed, can help you to solve difficult situations encountered when travelling. GT "Things to Know" |
Another option is to get on the phone as soon as you discover you need something like a pump and order an over-night drop from Opel GT Source. You can have them FedEx your part overnight to a motel room.
Chances are you could have filled the system with water at the gas station and drive a few miles to hole-up at a motel. Then drive somewhere the next day to an appropriate place to make the repair. (shaded, out of the way, empty parking lot near a parts store) Or, drive to a repair shop with the over-nighted pump and pay to have it installed. I'm not a mechanic, but I steer well clear of any type of stop leak type material. When your system loses coolant in the future it can coagulate and begin closing off coolant passages like an old bacon-lover's arteries. (can't find the emoticon having a heart attack) But since its already in, perhaps you can flush it out (but don't simply drain it out). |
4ZUA787
well i will have my water pump at noon tommorow but i found out today i will probally not have time to do it tommorow hopefully it will be fixed by the weekend. well the radiator stop leak i used is the military grade type got some from my supply guy and always keep it in my cars, i am deffinetly gonna flush the system though to make sure it is clean. in accordance to the other message i did have my 155 piece craftsman tool set in the back, so i was good on the tool factor, i had a fan belt, fuel pump, starter, points and condensor, starter and brake clean, oil 20/50 and 80/90, and silicone sealer as well i have a ton of military grade JB weld. the only problem about even overnighting the part from ogts would have been i trully didnt have enough time, i had to be at work at 0700 this morning or i would have been out-of-ranks which would have been very bad, if i had anthor day i probally would have. anthor thing do we still have that thing on this site that shows were all the members are from i know it was on here at one time, i tried calling my brother and have look on here for it and see if any fellow opelrs were near by that could have helped out.
SPC Juneau |
I know there is or used to be a site member in El Paso, but Gary has the member's map locked out with the new upgrade still being massaged.
4ZUA787
thats probably why my brother couldnt find it on the site he was trying to find it for me as i talked him through the site, and he couldnt find it, know i no its not accesible right now do to udgrades.
SPC Juneau |
