Unanswered: Aluminum Radiator
The aluminum radiator that I installed is originally used on Honda Civic and its size is very close to Opel GT radiator. I had to fabricate radiator brackets and to modify upper radiator hose and that was it! It took me about 3 hours. Here are some pictures. |
'72 Opel GT (Sara)
And it's nice looking too!
. It looks like it has a drain plug unlike the stock radiator...
I bought it from these people:
eBay Motors: KOYO ALUMINUM RACING RADIATOR 92-00 Civic Del Sol B16 (item 280244455287 end time Aug-08-08 00:55:22 PDT) I am surprised how they raised prices, though. I paid the radiator one month ago $49.99 + $40.00 S/H. They are now asking $284.99 + $200.00 S/H to Canada! ![]() I do not know what is going on but you should certainly shop around. |
That's the one I've been recomending for years for GTs, glad to see it worked out well for you.
![]() Provided Answers: 10
For you to get the extra 33% cooling this type of radiator offers, you must find one with twin 1" tubes which is approx. 2.25" in width. Godspeed makes one which is affordable and usually sells for about $90 with freight. The other part of this story is that it saves 10lbs on the front end of the car.
No fan shroud is needed the Electric fan is in front of the radiator
I think you need an extra nipple on the top of the radiator for the 2.4 EFI setup. I got mine from OGTS a few weeks ago. They had it special made for the EFI engines it was around $550. The only complaint that I have is that for that kind of money the brackets should be exactly as original and they are not so the install is not as pretty as it should be. The bottom radiator hose also is tight to the oil filter making it difficult to get the hose on and the filter off. I had to remove the filter at the end of my build just to be able to get the hose on. The good thing about it is that they made it so that the original 1.9 upper radiator hose can be used and they added the nipple on the left side to connect to the triangular tank. They also had a special bottom hose made that I bought along with the radiator.
Jeff '73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt, Ali Flywheel w/S10 Clutch, Electric Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold. 123 WHP @ 6800 RPM ![]() '64 VW Karmann Ghia '08 BMW M3 Last edited by markandson; 08-08-2008 at 09:29 AM. |
Here is the pic of my electric fan (still showing old radiator though). I put a piece of fuel hose around the fan to prevent fan touching the radiator. That ensured quiet, vibration-free functioning.
#11 (permalink) | |
Hoosier Opeler
Real Name: Ron
Nice. Thermostatically controlled or always on? Is there enough clearance with the new radiator to run a stock (belt driven) fan? Any reason not to use both? Ron in Indy |
Ron,
It is thermostatically controlled, 14" fan. The supplier claimed 2000 cfm. If you look the radiator pics earlier in this thread, you will notice sensor line in the upper hose. The thermoswitch incorporates 30A relay (this is aluminum box on the left side of radiator). Electrical fan alone keeps my engine cool at any stop and go condition (I have normal 1.9 engine). By removing standard fan, I gained few HP and engine works quieter. |
That thread came up just now, while I'm searching the net for an aluminum radiator... great souls think alike!
What are the overall width and height of this one, mine should go in my new "Jägermeister", I have a maximum space of around 18x18" available. Is there any website where I can pick a "standard replacement" by size (width x height x thickness) from any of the rice cooker's models? Dieter
Aluminum Radiator for A/T
Does anyone know if the Del Sol Aluminum radiator could be made to work on a GT that has an automatic transmission?
I suspect that the most common recommendation will be to change to a manual transmission - but since I already thought of that one I'm hoping for some additional suggestions.
If it's not leaking oil - it's out of oil! 1969 Opel GT ... visit my restoration project ... 2008 SRT4
#17 (permalink) | |
Supercharged 2.4
![]() What are the dimensions of the Del Sol radiator?
Real Name: Neil
Radiator Shroud
Does anyone have a pic of the stock radiator with the radiator shroud. My GT came with one but was not installed. I was told this is used to channel air in and improves the stock radiator without having to buy a new radiator or install an electric fan. I have yet to see a pic of one installed though.
Thanks Neil |
#19 (permalink) | |
Gumby, the automatic transmission cars have a cooler for the trans fluid installed in the lower tank of the radiator. It's actually a pretty common thing to do, most manufacturers do it.
#21 (permalink) | |
My other thought was to use a separate transmission cooler - since conversion to a manual transmission may be a future project anyway. eBay Store - racing guys store: Antenna Mast, Racing Short Shifter, Passager eBay Store - SKYNON'S TOOLS: MISC. INDUSTRIAL ITEMS, CONSTRUCTION TOOLS, NAME BRAND HAND TOOLS
#25 (permalink) |
Supercharged 2.4
FYI for anyone considering this radiator...
Ebay item: eBay Motors: CXRacing Radiator Civic 92-00 DEL SOL B16 B18 ALUMINUM (item 190247318232 end time Sep-02-08 17:59:31 PDT) Appears to be basically the same things (LxHxW all the same) for $40 + shipping (44.99).
