'72 Opel GT (Sara)
Unanswered: Valid Water Pump Leak Test?
Thoughts?Thanks, Matt
'72 Opel GT (Fireglow Orange) Third Owner, Purchased in 1986 Current Status: Fully Restored Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars, Custom CAI, Sprint Manifold Restoration Thread Comments Thread Other Cars: '09 Pontiac G8 GT (Panther Black) '06 Pontiac Solstice (Envious Green) '99 Oldsmobile Intrigue GLS (Black Onyx) Last edited by newman27; 08-23-2008 at 03:34 PM. Reason: Clarification... |
Real Name: Jim
![]() Provided Answers: 7
Agreed. It's possible you got a bad pump but more likely that the gasket is leaking. I prefer not to use gasket sealer when replacing the pump since a paper gasket is fine for the job if you take your time to remove every last bit of the residue from the timing cover.
Jim
'72 Opel GT (Sara)
. I better that get that thing off the counter before my wife gets home! Thanks for the comments...Matt
Matt as Jim as already mentioned if you'll clean the sealing surfaces the paper gasket should be fine. The FSM rates the cap pressures as 13.2-15.2. I had water pumps that didn't show rear signs of leaking until after you shut the engine down and it built up more pressure because of the heat.
Tip: You may want to only use water until you know it doesn't leak. Then you can drain it anywhere and add coolant when you're sure you have successfully fixed the problem. Harold |
When you get it back together call me at home I have my pressure tester here and we can check it . I will P.M. you my cell number .
John
#7 (permalink) | ||
'72 Opel GT (Sara)
Matt
'72 Opel GT (Sara)
OK, I can confirm that my rigged up test pictured in post #1 above is NOT a valid test. I put that pump back on the car and it leaked from the shaft anyway
. I pulled out my spare pump and a new gasket and so far no leaks after a day with a couple test drives taken. BTW, this latest pump is different than any others I have used. I've attached a picture from the Rock Auto website. Notice that the impeller blades are not open but rather enclosed in a solid casting. I also noted that this pump felt "tighter" when turning it by hand and that the shaft where the fan attaches is slightly shorter than the others I have used. My hope is that all this translates into a more robust, fail-proof water pump.The good news is that at this point I am an expert at water pump removal and replacement. I can have the radiator out of the car, hoses, belts, and the pump removed, and be cleaning the old gasket off the timing cover in about 15 minutes. Not bad for me anyway... Matt
That's a cast iron impellor, which is what our Opels came with from the factory. Most of the cheaper aftermarket replacement pumps use a stamped steel impellor which is not as efficient at cooling. I won't use the stamped steel versions in any performance engine...they don't cool as well due to cavitation.
#10 (permalink) | |
Too many water pump installations and not all of them as easy as the Opels. Right Matt? ![]() Harold |
#11 (permalink) | ||
'72 Opel GT (Sara)
![]() ![]() Matt
