Uber Genius
Answered: Closed cooling system. Advantages and disadvantages?
1) Cracked head 2) Toasted bearing 3) Timing chain slop skips a tooth I am not worried about #2 and #3 but the cracked head issue got me to thinking. Why didn't the 1.9 come with a closed system? With an open system you have to keep topping off the radiator which most younger people will forget. I know I did with my first one. When adding coolant to the hot head it has the best chance of cracking, even if the engine is running. A closed system makes the most sense, right? What are the advantages and disadvantages to converting a stock 1.9 to a closed system? Specs would be using the Stant SP-21, 14psi radiator cap (as suggested in another thread) and a minimum 2 qt overflow bottle. Thanks for the input.
Most Helpful Answer - Posted by RallyBob
From my experience the biggest reason the Opel heads crack is twofold. Later heads (1972-1975) crack primarily because they have induction hardened seats, and are VERY brittle. However all the heads are prone to cracking because of a tendency to run extremely hot at cylinders #2 and #3. The reasons they run hot include, but are not limited to: *Much higher exhaust flow at #2 and #3 exhaust ports, which leads to overscavenging, pulling still-burning air/fuel into the exhaust ports. *High exhaust flow in general compared to the intake flow, again causing overscavenging. *Exhaust manifold being 'open' and shared at cylinders #2 and #3. Individual tubes would run cooler. *No coolant passages or intake ports between exhaust ports #2 and #3. So they run hotter through convection as well, no incoming air/fuel to cool the ports, and no coolant to cool the ports. As as example, the center exhaust ports normally run about 200°-250° hotter EGT's than #1 and #4. And those outer ports still run hot...about 1400-1450°. Terminal for many other brands of engines! Balancing the exhaust flow, increasing the intake flow, and adding two extra 3/8" holes in the head gasket near the center exhaust ports can drop those temps by up to 300°. I'm not saying the heads can't crack at this point, but the chances are severely lessened! HTH, Bob |
Uber Genius
Modifying the head gasket was something I was going to explore but now I don't have to. Thank you.
Now, what are your feelings on the closed system?
Opel GTs are not GM products Last edited by First opel 1981; 01-19-2009 at 04:22 PM. Reason: spelling |
If you mean a pressure cap and overflow is captured in a container and when it cools off it sucks the water back into the radiator, then I have one on my 73, works great, just don't put the container in front of the radiator it make make it less able to cool by blocking portion of the fins.
Uber Genius
Yes, that is exactly what I was asking about.
Thanks for your input. I saw a picture of a reservoir bolted to the left of the radiator and looked like that was a perfect spot to mount one.
'NO,......O P E L..G T!'
Slightly off topic, but what's that you've got going over the top of the rocker cover?
As for closed loop systems, over in europe many of the owners go for the fully pressurised systems found in something like a Monza/Senator or Carlton engine bay, here's a pic from my old Monza GS/E, you can see the radiator is closed and is top-up tank is on the Right Hand side of the engine bay....could be the way to go?
Mark I used to have an Opel....now i have a collection ![]() 69 GT 2.5 FI, Getrag, Irmscher Big Brakes, LSD, Lowered, 8" & 8.5" BBS RM's, Leather.....ex Dealer Opel Team 70 GT 1.9 Weber, 4 Speed 70 GT 1.9 Twin Weber, 4 Speed, Alloys 71 GT 2.0 Weber, Getrag, Lenk Styling, Alloys 71 GT 3.5 V8 Holley, RHD, TARGA, Leather Recaros 75 Commodore GS Coupe, 2.5 Twin Carb, Auto 76 Commodore GS/E Coupe, 2.8 FI, Auto, Alloys, LSD, Sunroof |
#8 (permalink) | |
And make sure the remote reservoir (also called a surge tank) is mounted higher than the rest of the cooling system to prevent air pockets from forming. Any air pockets will virtually guarantee overheating!
#9 (permalink) | |
Uber Genius
On my Mustang and my Thinderbird (the only two cars I can look at right now) the recovery tanks are located below the radiator cap level. Why would an added recovery tank need to be higher on an Opel? Just curious.
#10 (permalink) | |
On some new cars this is an issue, Nissan 350Z's have the heater core as the highest point, and need about 6 hours to bleed the system of air or they will overheat every time! Ask any Nissan technician....
Uber Genius
Ah, you are speaking of the high end system, not the "add a cap and add a tank for $20" upgrade.
Now I understand. I am not ashamed to say I am looking for cheap cooling system insurance. I'm not building a racing machine but rather something that my son can drive and turn heads in. It's his money and, as most know, 19yo wages aren't quite perfect for high end upgrades.
#12 (permalink) | |
Uber Genius
I will keep those in mind. Not that I'm oppsed to going it that way or anything but I think the simple verflow system will suffice.
I did see a nice setup at OGTS for something like $600. (or was that a dream?)
'72 Opel GT (Sara)
I'm liking this idea because it bugs me that on the GT you can't really tell what the coolant level is due to the filler neck opening being stuck out away from the radiator itself (i.e., you can't look straight down into the radiator). Some coolant is always laying there in the filler neck it seems but that doesn't mean you are "full up".
#15 (permalink) | |
Not a dream for me, this is it.
1971 GT
Omg
Not to steal this thread....... I don't know what the h*ll half of the stuff under that hood does, but boy, it sure is perdy!
'72 Opel GT (Sara)
Overflow container...
Otto - can you recall what type of vehicle the overflow container in this picture came from?
Thanks! Matt
Uber Genius
Thanks for all the input
It appears that there is no downside to converting to a closed (reservoir overfow) system.
For the price of conversion, I can't think of better cooling system insurance.
#20 (permalink) |
'72 Opel GT (Sara)
Cross-linking thread...
For future reference, here is a thread specifically on the over-flow bottle. I've decided to go with the polished stainless steel bottle that "bosco" mentions. They are available on eBay. BTW, that set-up that "MrGing / Ging" came up with is pretty cool!
I have been trying to find a 14 PSI Stant cap and can only find 13 PSI caps locally. The SP-21 part number isn't registering anywhere either. FWIW, The FSM says to use a cap that is rated 13.2 - 15.2 PSI. That said, doesn't the single number rating on the cap translate to a higher SAE range like the FSM is quoting?
#21 (permalink) |
Uber Genius
Hey, thanks for that link.
I looked all over for the topic before I posted because I had heard people don't like answering questions twice. That other link shows quite a few options for overflow bottles.
#22 (permalink) |
wicked wagoneer
Real Name: Ron
The pictures and the talk of overflow bottles have me realizing something very funny.
The PO of my car and me in turn, (because i did'nt know any better) have been using the washer fluid bottle as a coolant overflow bottle.
#23 (permalink) |
Check out the plastic reservoirs found in Saturns. There are a ka-zillion of them available, their reservoirs are pressurized rather than "open", and they come with pressure-relief style caps.
An advantage of the plastic tanks over metal is the ability to quickly, and visually, confirm the system has a proper coolant level. IMHO it would be dicey at best to grab an over-flow tank from an open system style car and use it in a pressurized system. |
#25 (permalink) | |
'72 Opel GT (Sara)
Thanks! Matt
