Old 03-10-2006   #1 (permalink)
azopelnut's Avatar
azopelnut
Unanswered: Replacement for 75 fan and clutch
Has anyone found a source for the 75 fan/clutch assembly or a suitable replacement?
Paul "azopelnut" Heebink
1970 GT 12A-Rotary 5-speed
1972 GT 2.0, 5-speed
1974 Manta, 1.9 Auto A/C
1975 Fiat X19
azopelnut is offline
Old 03-11-2006   #2 (permalink)
Paul, I found both an NOS fan clutch (actually Beck Arnley after-market) and a new aftermarket water pump on eBay. I just saw a '75 water pump a few weeks ago, but didn't bid (one spare is enough! I keep telling myself). The clutches show up every few months.
But I don't see why you couldn't just use an older pump and fan, or even just an electric fan (with whatever pump you have).
Old 03-11-2006   #3 (permalink)
opelnut10's Avatar
75 water pump and clutch fan
You can replace the 75 with the earlier water pump. You will also need a earlier model fan pulley, and fan. It works out to be about the same cost as a 75 pump and is a whole lot easier to find.
opelnut10 is offline
Old 03-11-2006   #4 (permalink)
David McCollam
'75 fan and clutch
Paul,
Have '75 pump new and used fan clutch. What do you need?
Dave
David McCollam is offline
Old 03-11-2006   #5 (permalink)
azopelnut's Avatar
azopelnut
I need both a fan (my blades are cracked and one even has a piece missing)
and a clutch (I believe my is frozen). I found a older volvo fan and fan clutch (all one piece ) that I hoped would work but the fan was a bit to big and I didn't think trimming an inch off of each blade would be very balanced.
1975 Fiat X19
Old 03-11-2006   #6 (permalink)
azopelnut's Avatar
azopelnut
I thought that would be a good choice too but the 75 pump shaft is only 2 1/2 inches from the radiator surface (sems longer than the pre-75 pumps)and the 14" electric fan required needs about 3 3/4!!!
I like the idea of a electric fan especially with A/C here in Arizona!!
Maybe there is a 14" with even lower profile than the Hayden(Pep Boys)
1975 Fiat X19
