| 6C - Fuel System Solex, Weber conversions, Fuel Injection, Fuel Pumps, etc. |
Unanswered: Carb/Choke Problem
long time Opeler
If you say, the Choke engages when it warms up. Your Choke is way out of adjustment. I would check to see if it's hooked up correct and the setting are correct.
edit: oh, so now you change your symptoms. Don't know what to say now.
75 MANTA A "2.0 Euro stuff! Fun and Fast "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." Last edited by tekenaar; 06-23-2006 at 06:27 PM. |
Sounds like your carb is running lean ..check for vacuum leaks and make sure the acc. pump is working.HTH
long time Opeler
