+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 20 of 26
Thread: Drill new holes in 1.9 manifold or 2.2 head??
    Detroit,where my home was 2 Fast 4 U is on a distinguished road 2 Fast 4 U's Avatar
    Oct 2005
    Maria - Hoop, The Netherlands
    2,296
    I actually don't know where to put this.
    I'm going to put a carb on my 2.2. I made a template from transparent plastic and noticed, that if I move the the carb manifold up about 10 - 12 mm, the manifold openings match the ports in the 2.2 head.
    What to do with the pins that stick out?? Pull them out and drill new holes and put them in there?? Or drill holes in the inlet manifold??
    And last but not least: what is better an auto choke that works with cooling liquid, an electric one or rebuild it to manual??
    Opel Ascona;
    Only built from 1970 - 1975
  2. #2
    Jun 2003
    New Zealand
    5,690
    Modify Manifold
    Best to weld up and modify the manifold - welding and machining ali is easier and the head will remain standard if you ever change your mind and want to refit the fuel injection ... or find a 'real' 2.2 carb manifold for DSD Webers, for instance.
    There also needs to be some extensions welded on to the intake manifold -that stick down like the ones on the FI intake - to stabilize the manifold and allow the bolts to hold it on correctly.
  3. #3
    1000 Post Club opeldean is on a distinguished road opeldean's Avatar
    Apr 2003
    Overland Park KS
    2,012
    dapbmw has the part as I recall
    i believe I remember the "dapbmw at opetgt.com" sell the maniflod you need.
  4. #4
    former opel racer jeff denton is on a distinguished road jeff denton's Avatar
    Nov 2002
    near some glaciers
    2,839
    And there was a thread here about this before. I think Bob showed us how this is done.
    Would be neat if you really can just buy the right manifold!
  5. #5
    Jun 2003
    New Zealand
    5,690
    Here!
    Quote Originally Posted by jeff denton View Post
    Try this site: http://www.dbilas.com/dbilas_eng/index.htm
    ..and here is the post from the North Am. Distributor:
    http://www.opelgt.com/forums/opel-pa...ghlight=dbilas
    I have ordered a thermostat housing for my DSD Weber set up - will let you all know of progress.
  6. #6
    Oct 2005
    2,296
    Well I went and looked thru my spare parts and found a normal intake manifold for a double barrel Solex, drilled two holes in the manifold, and it fits perfect on the 2.2 head!!!! But I'll have to make something so that the M9 bolt covers more of the inlet manifold.
    BTW the bolts for the inlet & exhaust manifold are M9 x 1.25 mm and NOT M9 x 1.00 mm as mentioned in one or more topics.
    Another problem was the thermostat housing, I found a thermostat housing which is fastened with 2 bolts, I used 1 bolt opening [closest to the carb] and looked where the the other bolt would have to be made, I was lucky it came in a part that was thick enough to make a M8 hole. Now i have to make a back plate, because the thermostat housing sticks about 5 mm further out than the head.
    Last edited by tekenaar; 08-17-2006 at 01:49 PM. Reason: witch = heks; which = welk of welke
    Opel Ascona;
  7. #7
    The 2 holes thermostat housing is designed for 2.o litres CIH engine , you can use this on old 1.9 head after milling one surface chanell ( 5 x 5 mm) in order to assure one comunication between the right water hole and the main water passing. I had the same problem when I had to mount this housing on an old 1.9 head.
    Regards ,
  8. #8
    Oct 2005
    2,296
    I've made the back plate for the thermostat housing today from 5 mm thick brass, I also closed a small opening with some kind of filling compound because the opening had no use any more on the 2.2 head.
    Next in line to make is a rest on the outlet manifold for the inlet manifold so that not al the weight is on the manifold.
    I'll see if I can make some photo's of what I've been doing!!
    Opel Ascona;
  9. #9
    Oct 2005
    2,296
    Well I made some photo's of the new holes in the inlet manifold [photo #1]
    Intake ports about the same size [photo #2]
    Flange intake manifold higher, had to cut a little piece of the flange, so the bolt could be placed [photo #3]
    Manifold mounted, [need to "torque the manifold up" like Rally Bob did in a collom he wrote photo #4]
    Every thing mounted, need to clean the carb, btw [photo #5]
    Last edited by 2 Fast 4 U; 08-18-2006 at 06:07 PM. Reason: Text added for the photo's
    Opel Ascona;
  10. #10
    Oct 2005
    2,296
    And these are the photo's I made of the backing plate for the thermostat housing [photo #1 & #2]
    Extra M8 Hole for fastening the thermostat housing [hole to the far right] notice that the opening in the head is smaller than in the thermostat housing [photo #1 & #3]
    The opening I had to close [didn't have any use anymore] in the thermostat housing [photo #4] and at the flange side [photo #5]
    Last edited by 2 Fast 4 U; 08-18-2006 at 06:28 PM. Reason: text added for the photo's
    Opel Ascona;
  11. #11
    Jun 2003
    New Zealand
    5,690
    Important!
    1) The hole that you have covered is quite important as it allows the water to be circulated back from the water pump and through the engine block before the thermostat opens - when the motor is started cold.
    By covering that hole up you may overheat the motor as there will be no water circulation as it warms up till the thermostat opens.
    That hole is needed so you will have to drill through your brass plate at an angle to line up the water channel with the thermostat housing.
    2) Below is a link to a picture of a 3.0L fuel injection manifold showing the bits sticking down under the intake ports that are needed to get proper clamping and stabilise the manifold on the head. You need to get something like that welded on to your adapted intake manifold too.
    http://www.opelgt.com/forums/attachm...achmentid=3845
    Here is a link to the interesting Thread that pic comes from:
    http://www.opelgt.com/forums/fuel-in...=3.0+injection
  12. #12
    Oct 2005
    2,296
    Than there is a small problem, the hole between the two M8 holes doesn't go thru and that is where the chanel goes what I've closed. So I've got two options.
    #1 open the passage in the head drill a hole in the brass back plate and remove the stuff I filled.
    #2 make a passage in the housing to tha water pump or somewhere.
    Opel Ascona;
  13. #13
    Pleasant Valley, CT
    7,563
    The later EFI engines don't have the recirculation hole drilled through the head. This is why the two-stage thermostats are utilized, with the extra coolant 'bypass' hose. But, you can drill through the existing casting and use the bypass channels like on the older carbureted engines. Or alternatively you can drill/tap into the thermostat housing and the waterpump housing, and run a remote 5/8" line for the bypass.
  14. #14
    Oct 2005
    2,296
    measure the hole and see what wil fit for a plug, do I have to drill strate, under an angle and do I have to completly remove the material blocking the passage??
    But where do I tap into the waterpump housing, if I want to go with the other option??
    The remote 5/8" bypass line is that the inner or outer Ø
    Opel Ascona;
  15. #15
    long time Opeler deaner is on a distinguished road deaner's Avatar
    May 2006
    Fallbrook, Calif.
    297
    For what it's worth I had set of DSD that somebody had done what your doing. They made a T-stat housing spacer that relocated the factory housing a lilttle forward The spacer it's self bolted to the head then the housing was bolted to the spacer. It was done real clean. Where the bypass hole is, they slotted the hole to make a large "gotch". I have since sold it to someone in the Opel community. Before I sold it I made a pattern and blueprint of it. I can copy it and send it to you. (if I can find it).
    edit: I just remember where I have it. I can dig it out on Monday if you want.
    edited again: this time for my crappy gramar. next time I promise to have my coffee first.
  16. #16
    Oct 2005
    2,296
    @ deaner, please do!!
    Opel Ascona;
  17. #17
    May 2006
    Fallbrook, Calif.
    297
    You got it. Monday when I get to the shop I'll dig it out and send it.
  18. #18
    May 2006
    Fallbrook, Calif.
    297
    Quote Originally Posted by 2 Fast 4 U View Post
    I have the Drawing scanned and ready to send to you. PM me with you email address and I'll send it to you.
  19. #19
    Oct 2005
    2,296
    No way José
    The later EFI engines don't have the recirculation hole drilled through the head. But, you can drill through the existing casting and use the bypass channels like on the older carbureted engines.
    Well I'm sorry to say I tried to find the channel in the casting but no luck , I think that the channel in the 2.2 head never has been drilled ???
    But I was thinking if I drilled one or a few holes [small 3 - 4 mm] in the outer thermostat rim I would have a little flow thru the thermostat housing so that the thermostat could open when the cooling fluid warms up, or am I thinking in the wrong way???
    Opel Ascona;
  20. #20
    May 2006
    Fallbrook, Calif.
    297
    Mail sent.
+ Reply to Thread
Page 1 of 2
1 2 LastLast
