| 6C - Fuel System Solex, Weber conversions, Fuel Injection, Fuel Pumps, etc. |
#1 (permalink) | |
![]() No connection is needed on the regulator vacuum nipple for a carb installation. The manifold vacuum nipple below the brake booster fitting may be blocked if not using distributor vacuum retard . . . pollution control device which only works only at idle anyway. Connect others as indicated.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 11-14-2006 at 02:02 PM. |
thats the PDSI from a 1.6 only a 27 mm venturi . it must realy choke the 1.9 for top end you might want to look for a didta (normal 1.9 carb) inlet and a didta or weber to go on it to get the best out of the engine
Citing an old 1973 Solex book I have, more likely to be a 35PDSI (Opel carb) with a 26mm choke. BMW was the only 36PDSI user, also 26mm choke, on their 1500 and 1600 models, as far as I can tell. Only ones larger than these were the 38PDSIs, shared by DB (28mm choke) and BMW (30mm choke), and the 40PDSI (30mm choke) used only by BMW on their 2000 and 2002 (non-TI/TII/Turbo) models.
by my Haynes manual Opel used the pdsi part # 3441507 on the 1.6 manta A manual with a 1.06" /27mm your book might be more accurate than a never right
Copyright © 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell Last edited by baz; 11-14-2006 at 04:04 PM. |
'77 Manta B - yellow
carburettor
The carburettor, as I wrote in the begining of this topic, is Solex 32/35.
I have seen the same carburettor installed on some European 2l Opel Rekord Caravan. Anyway, I have an incomplete double barrel carburettor marked 'GM Varajet II' and the proper inlet+exhaust mainfolds (I'll take some pictures on them), the throttle linkage is missing... I intend to install it later (in the spring), as soon as I find an air filter box and the engine finishes it's first 1500 km after overhaul. Thank you tekenaar for the hints; the hose on the pressure regulator's nipple is only for dirt protection until I find a proper plastic cap. First of all I have to clean the engine compartment and to arrange the electric wires, for the moment they look like mess... Thank you, guys, once again for your support and helpful advices. Attached you can see a buddy's idea of how my blonde might look like...
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 11-15-2006 at 12:15 PM. |
beat me to it otto i have just scanned this to show too
Copyright © 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell Last edited by tekenaar; 11-15-2006 at 11:59 AM. |
carb.
I think I have created some confusions with my english...
- sorry, I'm not a native speaker The carburettor which is actually on my car is marked 'Solex 32/35' and it is single barrel. I've seen the same type on the 2 liter engines. I have home another carb, double barrel, marked 'GM Varajet II' (+ corresponding mainfolds) - on which I need the mechanism that links the throttle cable to throttle axis and the air filter housing. On this subject I will post some pictures next days. This last one I intend to use in spring, next year. I hope I am clear now... Last edited by emircea; 11-15-2006 at 12:01 PM. |
the confusion is because whats in the photo looks to be a PDSI and a 32/35 solex looks like the one below , a totaly different carb
#10 (permalink) | |
Hmmmm, could have been a bit clearer myself . . . perhaps should have said "possibly due to the "32/35" reference" instead . . . more general.
32/35 Solex - non-CIH carb
Yep, illustration shows that both primary and accelerator pump are on the wrong (Ford) side of the carb too, so it can't really be a stock CIH carb.
#12 (permalink) | |
otto unless im thinking of the wrong carb compleatly the varajet 2 is a sliding or "variable" venturi carb for the primery and a conventional fixed venturi for the secondery
the primery working like an SU or stromberg but downdraft i thought the throttle body injection was a different unit all together !! the diag i put up was for comparison and not clamed to be the GM one its just the first one i found to show that the carb in the photo is not the same but a pdsi
#14 (permalink) | |
. . . not the other way around!
