| 6C - Fuel System Solex, Weber conversions, Fuel Injection, Fuel Pumps, etc. |
gone Opel GT crazy!
Unanswered: My progress...
As a lot of u guys know my 69 GT was going to be a drag car,the original firewall was cut out and just a single break was left...meaning the whole firewall was cut out and a plain sheet of metal was added. here in the pics are what i had to do,the other thing is the radiator support i needed.[img] http://www.opelgt.com/photos//data/500/thumbs/2007_0506Image0015.JPG[/img]
Rex {Elda} "code green"1969 Opel GT 4 speed,Weber carb,Pertronix electronic ignition. 1972 parts car auto-RIP 1972 parts car -Rip {saphire}-1993 yellow nissan pick up 5 speed! 1993 red nissan pickup automadic (unamed for now) {Alexia}-1989 chevy camero {Elliott}-1978 Pontiac Firebird -1989 Ford probe(unamed for now) 17 years old -6 vehicles... and still moveing on ![]() WATCH OUT,I'M A OLD CAR FANATIC!!! ![]() Future wanna be concept and custom car designer/builder. |
Ah, that looks like step one of my pedal relocation mod.
So you plan to put it all back to stock? Shouldn't be too bad of a project.
#3 (permalink) | |
gone Opel GT crazy!
yea that's my plan anyhow
gone Opel GT crazy!
well now i finally have all my hoses on my car...only problem is i don't know which hoses go where in the retard and advance goes to which hose point (it's a 69 setup (2 diaframs)
any one know which goes where
gone Opel GT crazy!
1971 OPEL GT 1.9L 4-speed
hey you want to chat? please!
im doing the same exact thing to my car the guy was going to put a v6 in it hey you want to chat? please!
1971 Opel Gt 1.9L 4-Speed Hugger Orange
#8 (permalink) | |
gone Opel GT crazy!
really doesn't answer my question.
Distributor Retard Port
http://www.opelgt.com/forums/group-6...nnections.html
http://www.opelgt.com/forums/engine-...nnections.html These two threads discuss distributor and emissions hose routings. On three different GTs', I plugged distributor vacuum retard. My opinion was that distributor retard was for emissions specs and I was more concerned about distributer advancing, then retarding (back & forth). http://www.opelclub.com/TuneUpPart1bJune2006.pdf Last edited by Lindsay; 06-14-2007 at 03:41 AM. Reason: Added opelclub.com link |
#11 (permalink) | |
gone Opel GT crazy!
thanks Lindsay that helped a lot!
gone Opel GT crazy!
Hooked a battery to the car today and to my amazement everything works (not sure about clock)
put some gas in the carb and it fired up very quickly! it's nice to see everything working out great and coming together!
gone Opel GT crazy!
update
Rex {Elda} "code green"1969 Opel GT 4 speed,Weber carb,Pertronix electronic ignition. 1972 parts car auto-RIP 1972 parts car -Rip {saphire}-1993 yellow nissan pick up 5 speed! 1993 red nissan pickup automadic (unamed for now) {Alexia}-1989 chevy camero {Elliott}-1978 Pontiac Firebird -1989 Ford probe(unamed for now) 17 years old -6 vehicles... and still moveing on ![]() WATCH OUT,I'M A OLD CAR FANATIC!!! ![]() Future wanna be concept and custom car designer/builder. Last edited by opel kid; 07-04-2007 at 01:40 PM. |
gone Opel GT crazy!
here is the radiator support cross member in
the last pic is my main body problem... just wanted to throw this out there also but the {break} panel switch well when i push it the red light comes on but also my horns go off! before they didn't go off when i pushed it and i haven't done any re wiring...is this normal???
gone Opel GT crazy!
Well i put a new weber carb on today.
I have fuel going in carb. Moter startes than dies. pump the gas pedal 3 times it cranks than dies. i did not put my vacuum lines on yet , i'm going to put them on tommrow i hope that is my problem. Please tell me what you think.... This car wants to come alive but i need all of your advise.
#18 (permalink) | |
gone Opel GT crazy!
![]() :is anyone out there?
#20 (permalink) |
Does it die as soon as you let go of the key? If so then you may not have 12 volts going from the run part of the ignition switch to the coil. If it runs momentarily after letting go of the key trying to run but stalling out then you are possibly looking at something you changed from before like a vacuum (sp) leak or something with the carb you just put on. Good luck.
Mike |
#21 (permalink) |
Does this carb have an Idle Cut-off Solenoid? If so, it won't idle without 12volts going to it. It will start, but won't run well or idle at all!
Paul |
#22 (permalink) |
gone Opel GT crazy!
no it cranks than dies .
it acts like it used the gas i pump in than rus out of gas so it dies. the only place to hook up 12v is to the electric choke. i do have gas comming out of the vacuum port or the port where the pvc hose goes. so it seems gas is going in to intake than going out the pvc tube in sted of following threw to the pistons. Please tell me what you think
#24 (permalink) |
If the gas is a liguid gasoline and not a vapor Krewzer is right. New Weber? If used then it is possibly as was stated, a stuck float causing the gas to just run into the engine by overflowing inside the carb. Could be dirt between the needle and seat keeping the float from closing off the flow when the bowl is full. Or just stuck in the open position which could just jar loose when you open the top of the carb.
Keep us informed. One step at a time when troubleshooting a problem. Don't do mutiple fixes at once without first checking progress from the first fix. Mike |
#25 (permalink) | |
gone Opel GT crazy!
then i bought it
